anyone buy wheel and tire combo??
Old Sep 28, 2001 | 12:04 PM
BlackMax62's Avatar
looking into the wheel and tire combo to save some money on wheels...does anyone recommend doing this or buying them separate...i was looking into the ADR GT sport wheel on www.wheelmax.com ..the size is 18x7.5 and the tire size is 215/35/18...will that fit on my 98 max??? anyone with these wheels and/or tires recommend them...thanks for all the feedback...
sabe
Old Sep 28, 2001 | 12:18 PM
NickStam's Avatar
Re: anyone buy wheel and tire combo??
I used 225/40/18 on my 18x7.5 rims. You can also use 235/40/18. I'm not sure how the other size will affect the speedo.
Old Sep 28, 2001 | 04:11 PM
Micah95GLE's Avatar
The ideal sizes are 235/40/18 or 245/40/18. 215/35/18 is for Civics, and is way too small for a Maxima.
Old Sep 28, 2001 | 04:47 PM
samiam's Avatar
E36 ETR
sabe
I got a sweet deal on a set (Rims and Tires) from www.discounttiredirect.com great price, great selection, great service.
BTW what wheels are you thinking of?
Old Sep 28, 2001 | 06:22 PM
NYCe MaXiMa's Avatar
hmm.
Ok...
First # is the width of the tire, how much surface it touches
Second # is the height of the sidewall. plays the biggest role in the proper turning diamter of the wheel/tire, so if this # is wrong, speedometer will be affected.
3rd # is the inside diamter of the tire, basically what size rim it sits on.
For a 8" width rim, reccomended tire would be 235, but 245 would fit as well.. For a 7.5" 225 is reccomended, but 235 will fit. For a 7", 215 is probably best but 225 would fit too.... Now, On any of these rims, a tire 20 points wider would probably fit as well, like stock 2k SE rims are 7" wide and come wtih 225s, although usually 215 is the right size, 235s have been put on the stock 17s too....
Go to http://www.miata.net/garage/tirecalc.html for more info....
Old Sep 28, 2001 | 06:23 PM
Re: hmm.
Originally posted by NYCe MaXiMa
Ok...
oh yeah, and 35 is too thin for the Max on a 18" rim, like Micah said. 40 would be correct.
And another thing about the wheel+tire combos... It is more convenient to buy the wheels and tires from 1 place together because they will be mounted and balanced for you already when you get them, and it would cost less to ship them together rather then ordering rims from 1 place and then tires from another. But be careful and make sure you get proper size tires and make sure they are GOOD tires. A lot of places such as www.wheelmax.com have a tendancy to offer wheel/tire combos with tires too thin or just too ****ty in quality. 18 X 7.5" rims need 225/40/18 tires, or 235/40/18.
Old Sep 28, 2001 | 07:04 PM
BippuBenji's Avatar
Re: hmm.
Ok...
So, 245/40/18's would work with my Konig Verdict 18"x8"'s? I wanted to get the biggest tire that would fit and not rub or affect the speedo. Also, I thought that the 245's would fill in the wheel well a little bit. I thought 235 was the biggest, are you sure 245 will fit?
Old Sep 28, 2001 | 07:18 PM
Re: Re: hmm.
hmmmmm, I will NOT say I am 100% positive, but following the trend, people put 235 tires on 7" wheels, so if the rim was 1 inch wider, why can't a tire with the next size fit? I'm pretty sure they will fit, however, rubbing may be another problem... It depends on the off set. The smaller the offset the more the wheel will stick out (i think), so the more it sticks out the bigger the clearence from the strut is for the tire sidewall.... I think 235 is more than enough tire though...
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
Garrettz459
Aug 29, 2015 02:18 PM
cheftoo
Aug 24, 2015 09:20 AM
