Check engine light problem
Old Sep 30, 2001 | 11:25 AM
fnkmaster's Avatar
The check engine light was on in my car and when I did the ecu test, it gave me code 0505. I know this means that the ecu is working fine and there are no problems as per bill's sticky;
"DTC 0505
Diagnostic Trouble Code 0505 is "All Clear". It means the Engine Control Module is working and no trouble codes have been set.
However, Diagnostic Trouble Code 0505 does not mean nothing is wrong with the engine. All it means is that the Engine Control Module has not recognized a problem. There are some aspects of engine operation which the ECM does not check and therefore cannot diagnose. One good example is fuel pressure. There is no fuel pressure sensor, so there are no "low fuel pressure" Diagnostic Trouble Codes."
now my question is, i reset the ecu thinking that it would help, but once again the check engine light is on. Also would an exhaust leak cause the light to go on? I am not sure about the exhaust leak, but it definitely sounds like it. Any suggestions would help. Thanks.
Old Sep 30, 2001 | 01:32 PM
Daniel B. Martin's Avatar
Re: Check engine light problem
"DTC 0505
Please do another Diagnostic Trouble Code readout.
Perhaps you got that 0505 because you inadvertently reset the Engine Control Module before reading the codes. Don't be embarassed, that has happened to plenty of people. Now you have another chance to read the DTCs.
Old Sep 30, 2001 | 02:09 PM
Sonic's Avatar
Screw clockwise once, then back to the original position for the error code, do it twice to erase it.
Old Sep 30, 2001 | 03:28 PM
fnkmaster's Avatar
thats what i thought i did... i'll try it again and see what code it gives.
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
