motor cranks..but got a prob..need help
Old 10-01-2001 | 12:46 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
hey all
we got the trans up today and all electrical stuff hooked up. We cranked it initially to get the oil circulating. Only to discover oil is not circulating. I pulled the oil press sensor out and only a couple drops came out. We cranked it with it out and no oil came out...Is this the proper way to see if there is oil press? is there another way? thanks! man....we're REALLY discouraged...
Old 10-01-2001 | 08:43 AM
99NosMax's Avatar
Re: motor cranks..but got a prob..need help
Originally posted by Turbo95Max
hey all
did you check your oil level, is the sump in the oil pan clogged/not put back ???
Old 10-01-2001 | 09:13 AM
Daniel B. Martin's Avatar
hey all
Engine oil, lots of it, should come out. Something is wrong.
- you removed the wrong sensor
- there is no oil in the sump
- the oil pump is broken
- the oil pump pressure relief valve is stuck open
- the oil pickup is broken or clogged
Old 10-01-2001 | 09:47 AM
1MAX2NV's Avatar
Oil pump??
Old 10-01-2001 | 11:30 AM
Turbo95Max's Avatar
hummm
well, i know i removed the right sensor. We're gonna look in the pan to check the sump. The pressure relief valve is on the oil pump right? i know its ALOT of work to get to that pump....man this sucks!
Old 10-01-2001 | 12:19 PM
Location of oil pressure relief valve
... The pressure relief valve is on the oil pump right? ...
You might say it is in the oil pump. For further information please refer to the Chilton repair manual (page 3-39) or the Haynes repair manual (page 2B-18).
AaronL
08-08-2020 11:31 AM
D Mason
06-21-2016 05:43 AM
Unclejunebug
04-02-2016 06:42 AM
knight_yyz
11-01-2015 02:34 PM
