VERY annoying sound coming from climate control. PLESAE help!
Old Oct 1, 2001 | 03:26 PM
Nick Robinson's Avatar
Since yesterday my climate contorl has been making a very annoying sound. It sounds like a CD spinning, only louder. I know for a fact its somthing to with the climate control cuz if i turnit off, sound goes away, turn it on its back. I cant stand it anymore! Anyone have any ideas?!
Old Oct 1, 2001 | 07:16 PM
Ramius83
Mine is making a clicking noise too, anyone know?
Old Oct 1, 2001 | 07:31 PM
Daniel B. Martin's Avatar
Perhaps a leaf fragment or a bit of paper has got into the air duct and is touching the blower wheel. This is somewhat like the child's trick of clipping a card to his bicycle fork so that it hits the spokes to make a sound which mimics a motorcycle engine.
Removing the blower motor is a job which may be done by the home mechanic. This procedure is covered in the Chilton repair manual (page 6-8) and the Haynes repair manual (page 3-8).
Old Oct 1, 2001 | 07:51 PM
krzymax's Avatar
Maxima owner since 2000
or could it just be your fan working harder because you have your A/C on? i notice how i also get a noise comming out of the vents and stuff.
Old Oct 1, 2001 | 09:58 PM
KiLIAkLoWn's Avatar
same prob
I have the same problem, it is driving me crazy. I think it is comming from the passenger side. There is some kind of white plastic thing under the dash on the pass. side. But it is def. the A/C. i might have to take it to the A/C guys to figure it out, unless you guys find out what it is first.
Old Oct 1, 2001 | 10:22 PM
shadygrey's Avatar
yes yes...same prob here. It seems to be coming from the passenger side. Very annoying sound like the card in your bike spokes sound mentioned before. I hope its just some leaves caught in the fan. Any suggestions fellas?
Old Oct 2, 2001 | 07:25 AM
KiLIAkLoWn's Avatar
If all of us have the same problem then it might not be leaves.
Old Oct 2, 2001 | 07:34 AM
ru4real's Avatar
I think you're all crazy.
No, really, it could be leaves... those things have a tendency to fall from trees around now.
Old Oct 2, 2001 | 07:38 AM
njmaxseltd's Avatar
Perhaps someone with the noise should take the fan out and see what's inside
Old Oct 2, 2001 | 07:43 AM
The blower motor is located just above the passenger's feet. You could try giving the blower a (gentle) kick to see if it changes the symptom. This is suggested as a diagnostic measure, not a remedial one. If the motor is going bad or there is trash accumulation inside the duct, that blower has to come out.
Old Oct 2, 2001 | 10:01 AM
shadygrey's Avatar
Thanks for the advice DBM. When I started my car this afternoon and turned on the Climate Control I didn't hear the noise, suggesting that it is/was something caught in the blower. If the noise starts again i'll try the kicking thing and see what happens. I'll keep u guys posted.
P.S.
If that works I'll go around and kick everyones' blower absolutely free. Better than paying a nissan dealer 70 bucks an hour to do it.
Old Oct 2, 2001 | 12:04 PM
wow. I cant beleave everyone is having this problem!
Mine just started doing it, and it seems to becoming from the pass side. Im gonna go try the kick method =)
Old Oct 2, 2001 | 12:51 PM
DavidM's Avatar
solution to the problem?
just some info for my bros, I had the same problem with my 99 Max, clicking noise coming from passenger side vent, took it to dealer, they said almost all maxes have this problem sooner or later there's some sort of clip in the vent that was poorly designed and it works it way loose. The dealer said Nissan had "quietly" sent out a solution to the problem, a better designed gadget so the dealer replaced it and so far it seems to be working, definitely not as loud as it was....the thing I noticed most is how loud the damn fan is from the outside of the car when the AC is on.
Old Oct 2, 2001 | 01:14 PM
Re: solution to the problem?
Greeaaaaaaaaat. How much was it? And what was it exactly?
Old Oct 2, 2001 | 02:02 PM
shadygrey's Avatar
Cool, but I don't want a solution that makes it quieter than it was before. I wan the noise coming from my passenger side to be eliminated completely. Also, how much did the dealer charge you? I talked to my friend who used to work for Nissan and he said if it is something caught in the fan or anything minor he'll charge me 10 bucks.
Old Oct 11, 2001 | 05:42 PM
KiLIAkLoWn's Avatar
Did anyone find out what was wrong?? Does it need to be replaced or cleaned??
Old Oct 11, 2001 | 08:27 PM
Mines not doing it anymore
Old Oct 11, 2001 | 09:09 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
try using an air compressor and blowing around and seeing if it knocks whatever it is loose.
Old Oct 11, 2001 | 11:00 PM
emax02's Avatar
My max and I30 both make a anoying sound when the fan is set on level 3. I never really thought about fixing it, I will tomarrow though and I'll let you guys no what happened.
Old Oct 13, 2001 | 05:24 AM
still Oct 27th as a pickup
Old Oct 14, 2001 | 03:39 AM
Naughty
Re: Re: solution to the problem?
DO a search on my "name" and read the post thatI wrote a while back....its has all the information about it....Nissan has come up with a new "part" to reduce the noise.......if yor ***** enough the dealer will cover it as "good wil"
homeyclaus
Sep 3, 2015 06:15 PM
mrgooch
Sep 1, 2015 04:10 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
