Dtc 0707
Old Oct 1, 2001 | 07:10 PM
Yellowbrother's Avatar
Dtc 0707
DTC 0707
Diagnostic Trouble Code 0707 points to a problem with the Rear Heated Oxygen Sensor. This sensor is mounted in the exhaust stream, just downstream of the Three-Way Catalytic Converter. When the two Front Heated Oxygen Sensors are operating properly the Rear Heated Oxygen Sensor is not used for engine control operation. It is used to monitor the condition of the Catalytic Converter. If either (or both) Front Sensors fail, the Engine Control Module uses the signal from the Rear Sensor to maintain a correct fuel/air mixture.
DTC 0707 is detected when the Engine Control Module determines that the response time of the Rear Heated Oxygen Sensor is excessive. The possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted.)
- Rear Heated Oxygen Sensor
- Fuel pressure
- Fuel injectors
- Intake air leaks
Please check the condition of the wiring and connector at the rear Oxygen Sensor. If they look okay, you ought to replace the sensor. If you had a problem with fuel mixture I think you would have other DTCs in addition to 0707.
Your Maxima has three Oxygen Sensors. Two are front sensors, mounted in
the Y-pipe between the exhaust manifolds and the Catalytic Converter. One
is a rear sensor, mounted in the exhaust pipe downstream of the Cat.
When both front Oxygen Sensors are operating normally the rear sensor serves only to keep tabs on the Catalytic Converter. That's the reason your engine is running well. The Engine Control Module (the computer) is not using the signal from the rear sensor to control engine management functions.
For more information about Oxygen Sensors go to
http://www.volksparts.com/o2sensors.htm
For specific information about replacing Oxygen Sensors on your Maxima see
the Chilton manual (page 4-13) or the Haynes manual (page 6-14).
so does this mean my two front sensor is not doin it's job or does it mean only my rear sensor is f-ing up or does it mean all 3 is f-ing up?? thanx...
Old Oct 1, 2001 | 07:21 PM
Daniel B. Martin's Avatar
In a nut shell
This says it all, in a nut shell.
- Fuel pressure
- Fuel injectors
- Intake air leaks
Old Oct 1, 2001 | 08:16 PM
BRIGBOY's Avatar
Re: In a nut shell
- Fuel pressure
- Fuel injectors
- Intake air leaks
As far as the harness or connectors part goes, would that mean they have deteriorated and are exposed, or what. Thats the only part I have not fully investigated throughout my O2 sensor woes.
Old Oct 2, 2001 | 06:44 AM
Re: Re: In a nut shell
Examine the connector and the portion of the harness nearest to it for signs of physical damage. Sharp road trash may have bounced up and sliced the wiring in the vicinity of the sensor.
If you want to be thorough you could disconnect the Engine Control Module and measure the resistance of the wires all the way from the Oxygen Sensor to the ECM connector. However, my personal preference is to avoid touching the ECM wiring unless absolutely necessary.
Old Oct 2, 2001 | 05:34 PM
would it be a good idea to go on the safe side and replace all three o2 sensors???
Old Oct 2, 2001 | 05:55 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: Re: In a nut shell
So you think my chopping mine up to lose the speed limiter may have been a bad idea?
Old Oct 2, 2001 | 07:07 PM
There is no evidence to condemn the front Oxygen Sensors. I see no benefit in replacing good parts with good parts. If you do, go right ahead.
Old Oct 2, 2001 | 07:09 PM
Re: Re: Re: Re: In a nut shell
I am reluctant to mess with the Engine Control Module wiring. You are braver than me!
ef9
Aug 27, 2015 10:17 AM
iansw
Jul 13, 2003 10:59 PM
Soon2BMaxed
Aug 11, 2001 06:32 PM
enticiveblkmax
Feb 12, 2001 06:52 AM
