Wierd Tranny Problem !!
![goofy](https://maxima.org/forums/images/smilies/goof.gif)
Re: Wierd Tranny Problem !!
Originally posted by AntiVelvet
Help! My A/T is screwed up. I have a '95 and have the usual mods (intake, Y-Pipe, cat-back,jet computer, ect..) anyway I hope someone can help. Here is what its doing: Whenever it first gets started it stalls when it gets put in gear. It dosn't matter whether its first or reverse or what. Also it seems to have a mind of its own on which gear it wants to go in when Im driving. (anywhere from 1-70 mph) It will jump in and out of drive into O/D or second on its own. Something is really messed up, if I have it in park and put it in neutral, the engine still wants to stall but dosn't. Hey, if anybody can help that would be great!
When the clutch is disengaged the torque converter serves as a fluid coupling, allowing the engine to idle even though the car isn't moving. Your symptoms could be caused by ...
- a TC Clutch which cannot unlock.
- a fault in the control valve assembly such as a piece of debris jammed in the TC Clutch lockup solenoid valve.
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
