getting through the firewall...
Old Oct 9, 2001 | 11:12 AM
Soon2BMaxed's Avatar
hey guys i wanted to know, whats the best way to get through the firewall in a 95 se??? i need to run my power wire for my amp and my fogs too. thanks
Old Oct 9, 2001 | 11:46 AM
thrustinj's Avatar
You need to drill a hole and the fit a (can't think of the word) grommit or something in the hole to take up the extra space. They are made to fit the size hole you drill and wire you run.
...I think.
Old Oct 9, 2001 | 12:03 PM
jargoone's Avatar
...I think.
The purpose of the grommet isn't to take up the extra space. It's to prevent the insulation of the power wire from being worn away by the sharp edge of a drilled firewall. Best case, your main fuse at the battery blows and you have to replace it and the wire. Worst case, you weren't smart enough to have a main fuse, and your car goes up in smoke.
Old Oct 9, 2001 | 12:04 PM
clee130's Avatar
In my automagic 95 gxe, there is already a hole drilled into the firewall. But then again, I think that's where the clutch is supposed to go.
But the other way is to what thrustinj suggested. Drill a hole.
thrustinj's Avatar
Yes that is a better explaination.
Old Oct 9, 2001 | 12:58 PM
Nealoc187's Avatar
SLOW
BriGuyMax told me of a hole very near the extreme driver's side of the firewall, you have to take your fender liner out to get at it he said.
Old Oct 9, 2001 | 02:42 PM
SuDZ's Avatar
Might as well go for the one that is already there. I mean why add more if you dont have to? Also get the gromet to fill in space and also to protect the wires from rubbing against the metal and cutting. My friends amp was killed by this once because it shorted out by connecting there.
SuDZ
Old Oct 9, 2001 | 07:52 PM
97GreenMax's Avatar
Mine is the same way in my 97.
khantalha+
Jun 23, 2008 03:10 PM
rdbaron9
Jan 3, 2007 04:38 PM
Ritz
Oct 14, 2006 09:30 AM
suprropmp
Nov 12, 2004 06:53 AM
