idleing question
Old Oct 9, 2001 | 05:53 PM
operationNOS's Avatar
idleing question
I've got an interesting little problem... but I'm really not even sure it's a problem. I have a 96 auto GXE with basic mods, and I just recently noticed something with my idleing. In park, I idle at about 950 (same in neutral), but in drive, I sit at about 700. Is this normal? and if not... what should be done to fix it? is it really important? Thanx for any help you can offer.
Old Oct 9, 2001 | 05:57 PM
Sonic's Avatar
Is the car warm when sitting? If not, then that is normal.
Old Oct 9, 2001 | 06:24 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: idleing question
is this at start up or after the engine is warm?
i have a 97 automatic and my idle is about 725-750 at idle. normal is 725-800 i think. honestly, i think in D it is fine.
but the other seems high to me. let you car warm up. then turn on the a/c in park the idle should bog down to about 600 and then return to 750 or so, but not over 800. let it run for about a minute and then turn the a/c off the idle should peak up and then back down to about 750 or so.
the reason for this is, if it works as above then your car is operating normally. if not your idle adjustment on your throttle body may be off.this way you will put your engine under load while still in park and remove the load while still in park.
Old Oct 9, 2001 | 06:48 PM
Re: Re: idleing question
This is after my car is completely warmed up. With the ac on in park the idle sits at at least 850. What can be done to bring this to a normal level? I'm hoping DBM will happen to view this and give me his all mighty answer (sorry everybody else... but he really is good at this stuff).
Old Oct 9, 2001 | 07:02 PM
Bags's Avatar
Re: Re: Re: idleing question
do a search, what your looking for is the idle adjustment screw on your throttle body. it has been talked about 3/4 weeks ago. i am at work if nobody has given you a better answer i will look it up in my factory manual and give a better description.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
