Please Help - Check Engine light
Old Oct 11, 2001 | 07:13 PM
tifosiv122's Avatar
Hi. First, thanks for any help you can give. I installed a Stillen Y-Pipe, Rt Cat, Greddy catback yesterday. Yesterday everything went great, everything works. Same as all day today. About 9:30 tonight I was cruising at 65mph (actual cruise control). Everything seemed fine. I disengaged the cruise with the cancel button and the check engine light came on. Does anyone have a clue why or what I should do to fix it?
Thanks again,
Erik
Old Oct 11, 2001 | 07:23 PM
Maximum Pursuit's Avatar
Re: Please Help - Check Engine light
Thanks again,
Erik
My check engine light appeared several days ago after having my fuel filter replaced. I did a diagnostic test on my ECU using the instructions from the sticky Trouble Codes for ECU and found the problem but don't know what the DTC 1004 stands for.
Your check engine light could be related to an o2 sensor on your y-pipe - just a guess.
Old Oct 11, 2001 | 07:57 PM
tifosiv122's Avatar
Re: Re: Please Help - Check Engine light
I also had an oil change and trans fuel change.
Erik
Old Oct 12, 2001 | 07:06 AM
Sonic's Avatar
Thanks again,
Erik
Old Oct 12, 2001 | 08:33 AM
tifosiv122's Avatar
Originally posted by medicsonic
My sig has your seal of approval?
If it does, thanks.
Erik
Old Oct 12, 2001 | 08:35 AM
Sonic's Avatar
Re: Re: Re: Please Help - Check Engine light
If it does, thanks.
Erik
Got you to take notice, huh? Mods belong on the CarDomain page. Thank you. BTW,
Old Oct 12, 2001 | 12:49 PM
BSwithTF'sGirl
Have you ever had the recall work done on it?
My check engine light came on, I took it to the NIssan Dealership, and found out that my car had NEVER had the recall work done on it. THey changed a bunch of sensors (O2) and other things, for free and now it is perfectly fine--no problems since!
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
