water underneath my spare tire
Old Oct 14, 2001 | 09:02 PM
MaxC1Get!'s Avatar
I bought my '96 Max in January. When I first checked the spare tire a little while after I bought the car, I discovered water underneath the spare. I cleaned it up and thought the guy before me possibly left the trunk open and water got in. The other day when I opened the trunk, I noticed my trunk mat was damp in one corner. I took it out to dry it. Once again, I noticed approx 1-2 inches of water underneath the spare tire again. After I bought the car, I read that Nissan changed the design of the trunk for 97. Can anyone with a 95 or 96 tell me if they are experiencing the same problem. Do the 97-99 models get water? What exactly is the source of the problem and how can I fix it?
Old Oct 14, 2001 | 09:31 PM
hockeyghst's Avatar
Re: water underneath my spare tire
i have a 95 and i dont have any water problems.......except that one time when i got a flat tire and i had to change my tire and when i put my tools back i never wipped the snow off of them and the snow melted in my spare tire compartment but thats it.......other than that its very dry down there......
Originally posted by MaxC1Get!
I bought my '96 Max in January. When I first checked the spare tire a little while after I bought the car, I discovered water underneath the spare. I cleaned it up and thought the guy before me possibly left the trunk open and water got in. The other day when I opened the trunk, I noticed my trunk mat was damp in one corner. I took it out to dry it. Once again, I noticed approx 1-2 inches of water underneath the spare tire again. After I bought the car, I read that Nissan changed the design of the trunk for 97. Can anyone with a 95 or 96 tell me if they have/are experiencing the same problem. Do the 97-99 models get water. What exactly is the source of the problem and how can I fix it.
Old Oct 15, 2001 | 04:10 AM
Ramius83
Check the Weather stripping that lines the top of your trunk compartment that the trunk sits on when closed. To be honest with you, mine did that for about 2 weeks when I bought it, and this was happening everytime it rained. I checked the weather-stripping and it wasn't secured at some places, so it allowed water to come in. Good luck
Old Oct 15, 2001 | 09:16 AM
pocketrocket's Avatar
Hmmm, yeah, I'd go with the weatherstrip in the trunk too.
If that checks out ok, I'd probably consider:
a) spoiler seal (if equipped), mine leaks a little
b) Tail lamp assy weather seal.
Let us know!!!
Old Oct 15, 2001 | 01:04 PM
carnal_c30's Avatar
Former Sponsor
hmmm i had water in my 97 when I bought it, but since then the problem hasnt resurfaced, you are not alone
Old Oct 15, 2001 | 04:11 PM
shane's Avatar
What about the rubber seals thats on the outside of the spare tire space that could be offset maybe
Old Oct 15, 2001 | 09:09 PM
AgtXmas's Avatar
Its happened on other Nissans I've owned, but my Max hasn't had this problem. I'll go with group consensus here and say check the weather stripping.
Old Oct 17, 2001 | 02:21 PM
MaxC1Get!'s Avatar
Thanks for all of your suggestions! I found that the weather stripping that lines the top of the trunk compartment is loose in the middle of the strip. The rest of the strip is quite secure. Got inside the trunk, and a friend of mine sprayed the back window, tail lights and the trunk lid. With my light, I saw the water trickling in after 30 seconds of spraying water. Now the question is, how do I fix this problem? Thanks for your help.
Old Oct 21, 2001 | 05:40 AM
Go to your auto store, I should think they'll have a glue you could use to secure your weatherstrip to the metal lip
Old Oct 21, 2001 | 05:52 AM
Sprint's Avatar
check the black plugs in the bottom of the wheel well
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
JonBlz
Oct 5, 2015 06:02 PM
sliptap
Sep 30, 2015 05:57 AM
