Airbag suspsneion.......yes i searched........
Old Oct 14, 2001 | 09:35 PM
hockeyghst's Avatar
ok i want to get an airbag suspension kit for my 95 max....
i dont wanna spend a lot of money......does anyone knwo fo a cheap kit price wise???
do i need my struts/shocks and springs with the airbag kit??? or airbag cylinders......whatever they are called........is there a kit where it fits the maxima w/o any custom brackets???? thank any info is greatly appreciated...
Old Oct 14, 2001 | 09:52 PM
Ants97SE's Avatar
You are not going to get a good airbag suspension for cheap that you will like. If you go the cheap route you will regret it. My bud here in San Antonio runs a shop, http://www.thrill-factory.com He can set you up with parts, ideas, and other things you might need for an air ride suspension. If they are done right, they are great.
Old Oct 14, 2001 | 10:05 PM
thebigsadler's Avatar
you pay for what you get... talk to alex and southwest autoworks.. search "max8mycash"... good guy.. i have the kit in the mail.
Old Oct 15, 2001 | 06:06 PM
dko's Avatar
dko
duck and cover
You sure?
Make sure you want it first. It can make for some muddy handling and a real bouncy ride. Check out Greg's Max (http://www.custommaxima.com/AirBagKit.html) or max8mycrash (mentioned already) @ http://forums.maxima.org/showthread.php?threadid=69675
Don't think you'll get away with it being a bolt-on. Also, price varies with what you want. Front/Back adjustable kits are $1800 (from max8mycrash) and I have no idea how much Greg's system cost. Prob. a sick amount of money because he had to have it custom-fitted.
Old Nov 5, 2001 | 11:11 PM
SiMpLyMaXedOuT's Avatar
is it possible to have air cylinders alll the way around
wiht out using bags because i heard that bags pop often and basically our screwed then...what the price if you get cylinders all around? instead of just teh back.
Old Nov 6, 2001 | 01:18 AM
SuDZ's Avatar
Is airbag suspension the same as coilover or is it something else all together?
SuDZ
Old Nov 6, 2001 | 04:40 PM
dko's Avatar
dko
duck and cover
There is a relation in the sense that they both strive to give you control over your ride height. Airbags are just what they sound like, bags full of compressed gas that can be quickly inflated or deflated. The maxima kits tend to be ones that can be dropped anywhere from 1.5" form normal ride height up to (or down to, actually) about .5" from the ground or so.
ThomasofSodor
Mar 22, 2018 08:18 PM
ToTheMax305
Sep 23, 2015 09:11 PM
Colossus
Sep 9, 2015 05:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
