Anyone know how to replace a 95' Timeing chain
Old 10-14-2001 | 11:10 PM
asianpr3082's Avatar
If anyone know how to do a replace or look at the timeing chain for a 95' maxima reply to this post thanks
Old 10-14-2001 | 11:22 PM
Kashoggio's Avatar
yyou really should have to replace it and if you do this will cost you a nice amount
Old 10-15-2001 | 12:16 AM
emax02's Avatar
I think waht Kashoggio meant to say was:
You really should "NOT" have to replace it and if you do this will cost you a nice amount.
I agree with this statement. If you know your chain needs to be replaced you will have to take your timing case cover off and do some nasty work. I suggest you buy a repair manual before attempting this job because if you screw up it could prove fatal{to your engine}.
Old 10-15-2001 | 12:55 AM
I know that when you take off the case a lot of oil would come off i just want to look at it maybe look at the tension thing that hold the timeing chain down
Old 10-15-2001 | 01:30 AM
emax02's Avatar
Theres a few timing chain axcess{s?}covers that can be removed, maybe you can see what you want from there? One of the covers is located up and to the left of your idler pulley, there are 4 12mm bolts there, after you remove it the cover thingy you have to apply a new liquid/paste type of gasket/seal. Another thing you could do is to try taking of your oil cap and shining a light in there. You could also remove your valve cover, from there you should get a nice view. BTW why do you want to look at your chain?
Old 10-15-2001 | 01:35 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
why do you want/need to replace your chain? anyways, labor on replacing timing chain is 10+ hours. Its not an easy task and if your not pretty mechanically inclined i would leave this up to a shop.
Old 10-15-2001 | 08:03 AM
Kashoggio's Avatar
Old 10-15-2001 | 08:52 PM
Road beast tell me how u did it did u have to take out the engine ? if not tell me how u change the tension thing cuz i think that needs to be replaced cuz of the ticking sound that i am hearing might be from that unless its the valves yeah tell me how u did it thanks!!
Old 10-15-2001 | 09:01 PM
Old 10-16-2001 | 11:47 AM
emax02's Avatar
Get a repair manual dude, you don't want to screw around with your timing chain! BTW the clicking noise is usualy from the valves clattering when they get older. My car makes a ticking noise for about 3 seconds after I start it in the morning.
vingodine
45
05-21-2016 01:46 PM
maxinout93
10-27-2015 02:29 PM
Balkins
08-12-2015 07:39 AM
laparka66
08-06-2015 10:36 AM
Tanvirkamal
08-05-2015 02:32 AM
Quick Reply: Anyone know how to replace a 95' Timeing chain
