RPM's drop when coming to a stop....
Old Oct 15, 2001 | 10:36 AM
RICOiz704's Avatar
RPM's drop when coming to a stop....DanielB?
Normal driving everything seems cool..but when Im coming to a light and the car is coming to a rolling stop...the RPM"s drop to about 500 for .5 of a sec then bounce back up to normal...you can feel it also...I was wondering what could contribute to this. I ran a ECU diag. and came up with nothing even tho my check engine light is on..the code I came up with was 05 05 no problems detected. I have yet to lotctite my ambient sensor into my CAI i was wondering could that play a role...or maybe a fuel filter? Just wondering if anyone could help..
Thanks in advance
Old Oct 15, 2001 | 12:57 PM
NUGE's Avatar
my 96 SE is an auto and I have the same problem. Not sure what its from.
Old Oct 15, 2001 | 01:20 PM
nismo2020's Avatar
Needs non-Maxima Friends
Re: RPM's drop when coming to a stop....
Thanks in advance
dude i have the same problem. anybody know how to fix this?
Old Oct 15, 2001 | 04:31 PM
0oRICKo0
dammit same thing here
i got the same problem... but i think i have it worse then u all do cause like when im in second gear and sometimes in third like my car hesitates a lil ... and like its really weird....
someone help us please
-RiCk
Old Oct 15, 2001 | 04:37 PM
0oRICKo0
-RiCk
Old Oct 15, 2001 | 04:46 PM
Stillen_I30's Avatar
i experience this also. also, lately, i hit the gas, it shifts out of first and into second and it feels like the car is suddenly 1000 times heavier...it hesitates SO bad. i have to push the pedal in harder just to gain some more speed. happens when i shift into 3rd too. funny thing is...it will somewhat subside 5 mins later, but then return to this state again. sometimes i floor it, and it picks up speed VERY slowly...
Old Oct 15, 2001 | 09:10 PM
enticiveblkmax's Avatar
i had the same problem. i simply raised my idle speed to 800 and it
took care of the problem. my intake sounds nice too, a loud hissss.
Old Oct 16, 2001 | 03:55 AM
nismo2020's Avatar
how much and where did you get the pacesetter sts?
Old Oct 16, 2001 | 07:27 AM
Maury's Avatar
MAFS?
hi guys - it sounds alot like symptoms i was having a month ago, and it turned out to me my mass air flow sensor. th haynes manual shows you how to test it, but mine tested ok and still was faulty. at first it didn't set of a check engine light, but eventually it did. after replacement i was good to go. good luck.
maury
Old Oct 16, 2001 | 08:08 AM
NmexMAX's Avatar
dot dot dot ...
Re: MAFS?
maury
Could u post instructions how to run a test on the MAF, and also, how much is a new one?
Old Oct 16, 2001 | 08:42 AM
i think a new one is around $320 bucks. i could be wrong though...
Old Oct 16, 2001 | 10:28 AM
Maury's Avatar
Re: Re: MAFS?
hi NmexMAX. sorry, but i'm in a bit of a hurry to get to a doctors appointment. for now, the quickest way to test for the mafs is to check your car for the code. check the sticky on ECU codes and if the car gives you the mafs code - replace it. i paid $200 for a rebuilt one from Cardone. used ones can be found for $75 on up at car-part.com. good luck & i'll check back later when i get home.
maury
Old Oct 16, 2001 | 10:43 AM
matty's Avatar
no no no
Its not the MAF sensor...If DMB was on right now he would give a quick exlanation and i know he has in the past...It is the Idle Air Control Valve that either needs to be cleaned or replaiced....Do a search on the subject and there will be print out of DMB's exlination of the hole problem...Trust me...mine does it but i havent cleaned it yet...does it worse when it is cold out..
Old Oct 16, 2001 | 10:17 PM
whats the best way to clean the IACV-AAC? I will plan to just use the same TB cleaner i used in my TB cleaning...is this ok?
Old Oct 16, 2001 | 11:17 PM
Maury's Avatar
yeah, i just took the iacv housing off the car, opened it up and sprayed tb cleaner everywhere i could. i wiped it clean with a rag & it made a big difference. good luck
maury
Old Oct 17, 2001 | 01:59 AM
SkyXRacer's Avatar
I had the exact same problem. When you're driving and you're pressing on the brakes to come to a stop the rpm sometimes drop below 500 and slowly goes back to normal. I've been trying to figure out what it was for six months and I finally figured it out. I cleaned my throttle body and it solved my problem. Buy some trottle body cleaner not carb cleaner. Take off the trottle body and clean it with a toothbrush and wipe it clean with a lint free cloth.
Old Oct 18, 2001 | 05:41 PM
190hpKiLLA's Avatar
Granny Driven
Please help.
Can someone give me a dicent answer for God sakes! PleaSE DONT POST if you have the problem. Give answers. I have a 5spd and when shifted to neutral and waited till it goes all the way down it drops to 500 and then back to normal. ONLY WITH LIGHTS ON THIS HAPPENS> Please tell me what to do. People in this forus give alot od advice but none of them are sure to qure the problem. Thank you.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
