ypipe + cat or ypipe + udp = more hp
Old Oct 15, 2001 | 01:05 PM
gjabo178's Avatar
I’m definitely getting a y-pipe, then I’ll have about 200 dollars left.
The question is; Should I get a udp or cat?
From what I’ve researched the udp will free up more horses than
The cat will provide, but do you lose out on any of the horsepower increases of having an aftermarket y-pipe because you don’t replace the other exhaust components?
Much Thanks
97 Maxima
Old Oct 15, 2001 | 01:06 PM
clee130's Avatar
The y-pipe and exhaust go together. Like pigs in a blanket.
BRIGBOY's Avatar
Installation Costs?
Better get the cat.
Old Oct 15, 2001 | 01:42 PM
breaux124's Avatar
If you don't have it, get a RSB instead.
Also, do you have an intake? If not get that.
What mods do you have?
Old Oct 15, 2001 | 02:29 PM
fnkmaster's Avatar
Y-pipe + catback = more hp
Y-pipe + udp = almost same hp as y pipe
Once again UDP does not ADD horsepower... it just FREES up hp.
Old Oct 15, 2001 | 02:44 PM
Jon91SE's Avatar
Pusssseeeehhhh
Every mod FREES up HP, only thing that adds HP is boost........
Old Oct 15, 2001 | 02:52 PM
dwapenyi's Avatar
The cat doesn't really add that much, the y and udp combo should do better. The install of the udp is more difficult, though. I have the y and cat, and I really didn't notice the cat.
Old Oct 15, 2001 | 03:16 PM
La Jolla Max's Avatar
The cat just quiets things down worth maybe 1 or 2 hp. I mean, if you have the $$$ and want a complete high-flow exhaust, by all means go for it. Otherwise, get the pulley.
Old Oct 15, 2001 | 03:26 PM
theblue's Avatar
Re: ypipe + cat or ypipe + udp = more hp
Much Thanks
97 Maxima
if you don't have an intake then get one - you need an intake with a y-pipe or you're throwing your money away. then worry about cat + exhaust. Also your need for a cat depends on the number of miles on your car alone. don't expect more than 2-5 HP from any cat-back exhaust
Old Oct 15, 2001 | 04:33 PM
ToYLeT902's Avatar
JET Speed Lab
Old Oct 15, 2001 | 07:39 PM
fnkmaster's Avatar
thats not what dynos say... either way, i thought he was asking about a catback exhaust... my bad
if u r thinking between the convertor and the udp... definitely the udp. and as theblue said, get an intake
Old Oct 16, 2001 | 07:29 AM
gjabo178's Avatar
FSTB and stillen intake
Old Oct 16, 2001 | 09:16 AM
BriGuyMax's Avatar
UDP is SOOO much more worthwhile than the cat...I have one and I love it...of the mods that I have...it's on of the three that you can actually FEEL....including y-pipe and NOS.
Old Oct 16, 2001 | 09:29 AM
breaux124's Avatar
Would you recommend the UDP more than the RSB though?
Cost are about the same, but install on the RSB is really easy.
UDP may be worth the money, but would you get this before the RSB?
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
