windshield washer leds???help
Old Oct 15, 2001 | 02:48 PM
t0mt0mboy's Avatar
hi there...can someone help me...i can't seem to remove the factory windshield washer from the hood...can someone tell me how to remove it...thanks
Old Oct 15, 2001 | 04:39 PM
ToYLeT902's Avatar
JET Speed Lab
unplug the hose for the water, use some needle nose pliers and pull. not to hard. feel around its like a clip thing up there.
Old Oct 15, 2001 | 05:42 PM
WaarrEagle's Avatar
Re: windshield washer leds???help
I removed mine and ended up breaking both of them. So be careful!
Old Oct 15, 2001 | 09:18 PM
t0mt0mboy's Avatar
thanx for the response...i believe i've seen the hose...but how do remove that washer nozzle...is there like a clip there
after i remove the water hose...i don't wanna break it while trying to remove it...thanx for the advice...i'm pretty sure i would break it too...can ya'll help
clarifying what i need to do...thanx again
Old Oct 15, 2001 | 11:57 PM
Llfe's Avatar
it's like a clip...u have to push in both sides from under the hood...just get a screwdriver...and do front and then it should pop out easy
Old Oct 16, 2001 | 07:23 AM
Dreizehn's Avatar
Push it as far as you can towards the rear of the car... that should help...
Old Oct 16, 2001 | 08:10 AM
kaniksu's Avatar
I messed up one of mine before I was told how to remove them as well, I spent like 20 minutes on one of them... Once I learned how it took me 3 minutes to remove both of them....All you have to do is push the two clips on each side (you can feel them with your fingers) towards the center of the hose connecter. It was easier for me to push one in and then at the same time push the washer out on one side and then do the other side and it will pop out quick.
Also, when putting in the new ones... be careful... I dropped one of the black spacers into the hood and lost it forever It was the large one too....
Alec
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
