testing coil packs
Old Sep 16, 2007 | 12:03 PM
kv2's Avatar
kv2
testing coil packs
so i think one of my cylinders is misfiring. i wanted to test the coil packs to see if they were the culprit or the plugs.
if i were to test each one for a change in engine noise/spped, do i physically pull up the coil from the socket or do i disconnect the electrical connector? i do this while the engine is running right?
thanks!
Old Sep 16, 2007 | 01:39 PM
VQ30DETT's Avatar
http://forums.maxima.org/showthread....ting+coil+pack
this should help you out, i used this information to solve my misfire which was caused by a bad fuel injector
Old Sep 16, 2007 | 02:53 PM
kv2's Avatar
kv2
ok so i got the 0607 code now which says cylinder 2 misfire.
what can cause this? the spark plugs or coil packs right? anything else i should be aware of?
i am able to swap around the individual coil to different cylinders without doin any harm?
Old Sep 16, 2007 | 03:10 PM
VQ30DETT's Avatar
http://forums.maxima.org/showthread....ylinder+number
i would ohm out the coils, no swapping. check fuel injector too, lastly check plugs
Old Sep 16, 2007 | 03:55 PM
kv2's Avatar
kv2
hm what seems to be bad about swapping coil packs around to test?
you and other instructions online say not to do so (the rear ones, at least). aren't they exactly the same thing?
Old Sep 16, 2007 | 05:01 PM
lexoid's Avatar
Front and rear coils are different. But I don't see why you shouldn't change coils in the same bank. Beside coils itself, other possible causes for a missfire could be: a bad fuel injector, intake air leak, insuficient compression.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
