Weird idol while stopped
Old Sep 18, 2007 | 09:16 AM
Jimothy12's Avatar
96 SE 5 Speed 192K miles
Recently when I come to a stop my RPMs will return to about 500-600 which is normal but after a few seconds idolling the RPMs will bounce down to about 100. The car will shake then return to a normal idol. This has been happening at every light since Saturday.
I'm not showing any codes. Any suggestions?
Old Sep 18, 2007 | 09:47 AM
DarkangelYoshi's Avatar
What most people say to that question is usually a bad ignition coil pack.
It's hard to tell which one until the CEL comes on according to my mechanic.
I was proposing this:
Could you pull the ebrake up and then set the car in drive or reverse to stimulate load on the car to tests for which coilpack is going bad? I am starting to get really annoyed but my engine *thumps* as well. CEL has not come on.
Newbie here, so don't take my words too srsly. I'm just making a guess.
Old Sep 18, 2007 | 09:48 AM
nearthisbridge's Avatar
Possibly a misfire, it may take a while for a code to pop up for it. I had the same thing happen when I had a bad coil pack, so I'd check those.
Old Sep 18, 2007 | 01:32 PM
Snypa's Avatar
coilpacks are 4th's "best friend"
Old Sep 18, 2007 | 01:43 PM
Jimothy12's Avatar
Are there instructions on how to replace the coils? I've been a member of this forum since it started and for some reason I don't have access to use the search feature
Old Sep 18, 2007 | 05:34 PM
pmohr's Avatar
No more Maximas...
You can free search, but forum search is for donating members only. Surprised you wouldn't know that if you've been here that long. EDIT: Forums were around before 2002, btw.
Coil packs are simply two bolts each, remove, replace.
Old Sep 18, 2007 | 06:18 PM
dr-rjp's Avatar
When I saw, "Weird idol while stopped," I almost was going to recommend an expert in pagan artifacts. :-)
Old Sep 20, 2007 | 09:55 AM
Jimothy12's Avatar
"EDIT: Forums were around before 2002, btw."
FYI: I got a new screen name when I got a new max.
Should I just wait for a code or should I look more into this now?
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
