starter fix failed?
Old Sep 19, 2007 | 12:46 PM
flynlr's Avatar
starter fix failed?
I had 1 day of silence from the starter after cleaning and re greasing the gears in it.
the whrrrrr howl is back but not as loud as before. I was pretty liberal with the grease but am wondering if I should have really packed it in there.
how much grease did the rest of you use?.
Old Sep 19, 2007 | 02:23 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Did mine a good 5 years ago and have not had a problem since. I used just a very little bit (just enough to coat the gears) of AMSOIL Series 2000 synthetic grease.
Old Sep 20, 2007 | 12:33 AM
flynlr's Avatar
hmmm I may try another grease then. I used some lithium based stuff.
Old Oct 3, 2007 | 02:08 AM
flynlr's Avatar
well I took the starter back out a few days ago . and took it apart again. and I really slathered the grease in there this time. I mean I really stuffed the gears full of grease. after putting it all back together. a 30 min total job start to finish.
no more howl/
Old Oct 3, 2007 | 06:13 AM
Curt Deiner's Avatar
I did the fix last week. Mine was more the bendix action up and down that was sticky more than the gears. I put just a bit of caliper slide grease on my gears and sprayed the shaft with tri-flow then air hosed the excess off. I didn't want to remove the c-clip and take it completely apart, and didn't have a good tool for it.
Old Oct 10, 2007 | 10:30 AM
max4evr's Avatar
You know, I tried this grease trick twice, and it worked for a few months each time. The third time, I decided to just go out and pay the man for a reman motor (but not from Nissan; they wanted like $300 for their reman). Turns out if you have an early Max (95-96), they had a weak 8-tooth starter motor that's been superseded by a 10-tooth motor. All you can get now is the 10-tooth motor. It meshes just fine with the old flywheel, and seems to spin the engine over faster than even a regreased old motor did. If you have a later Max with a 10-tooth starter, it might not make as much difference.
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
