car wont start:(wel
Old Sep 19, 2007 | 09:55 PM
Tino98max's Avatar
car wont start:(wel
well long story short, went to start my car, didnt start, it just made a clicking noise, lights in the car, came on, and everything, but car didnt start, and when i opened the hood, it made a grinding/clicking sound, is this the battery, i did replace the battery a few months back, and i drove the car to the mall, and 2 hours later, i came back, and it didnt want to start, any solutions
tino
Old Sep 19, 2007 | 09:56 PM
helps
clicking as in the starter is actually engaging or as in just like a dead battery?
Old Sep 19, 2007 | 10:00 PM
Tino98max's Avatar
its trying to engage it seems
Old Sep 19, 2007 | 10:01 PM
Tino98max's Avatar
well when i turn the key, i get nothing, and then right after there is clicking noise
Old Sep 19, 2007 | 10:03 PM
helps
check the contacts on your starter, disconnect your battery cable when working with it tho. If you really want to see if its that, put on gloves, get a big screwdriver preferably insulated and cross the two contacts on the started with the key in the on position, if it turns over and starts bingo
Old Sep 19, 2007 | 10:06 PM
Tino98max's Avatar
my question is, why would it be the battery when it was replaced not that long
Old Sep 19, 2007 | 10:09 PM
helps
i didnt say it was the battery, are your lights dim? check your grounds? Clean the contacts on your battery?
Old Sep 19, 2007 | 10:10 PM
Tino98max's Avatar
i did clean the contacts, its just when it does try to start, the lights do get dim, and then dissappear
Old Sep 19, 2007 | 10:11 PM
helps
manual or automatic?
Old Sep 19, 2007 | 10:12 PM
Tino98max's Avatar
auto
Old Sep 19, 2007 | 10:15 PM
helps
i say try the touching the contacts idea with the key on, if that doesnt work then its not getting enough power to start meaning wiring or battery, if it does start its the contacts.
Old Sep 19, 2007 | 10:22 PM
Tino98max's Avatar
ok ill try and u jumper cables to get it out of the parking lot first, and then use that idea
Old Sep 19, 2007 | 10:36 PM
helps
wait jumper cables work?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
