I have a Q which i hope someone can answer...
Old Sep 20, 2007 | 08:16 AM
icedout's Avatar
Is this statement true.That if you do a 5spd swap and keep the auto ecu in the car that car will be slower then if you had the manual ecu in the car.Is there any truth to that or is it bs.
Thanks guy
Old Sep 20, 2007 | 08:51 AM
pmohr's Avatar
No more Maximas...
Thanks guy
AFA the engine is concerned, the ECU has the same programming whether the ECU be for a 4AT or 5MT.
Old Sep 20, 2007 | 09:05 AM
icedout's Avatar
so in other words there no difference?
Old Sep 20, 2007 | 09:09 AM
pmohr's Avatar
No more Maximas...
...as far as the engine is concerned, no.
Old Sep 20, 2007 | 10:17 AM
icedout's Avatar
meaning what? iam askin is there a different in the shift points,is there goin to be lack of somthing in the manual because theres not a manual ecu in it.Basicly is it worth it to put the maual ecu in the car over haven the auto one in there already.
Old Sep 20, 2007 | 10:22 AM
pmohr's Avatar
No more Maximas...
Now pardon me if I'm wrong, I'm not all too familiar with cars or anything, but with a 5MT do you not set your own shift points? Something about pushing that weird extra pedal and moving that lever thingy, makes it shift.
It's worth it if you don't want CEL's, yes. Otherwise, as I've said twice above, EC programming is the same on both computers.
Old Sep 20, 2007 | 10:30 AM
icedout's Avatar
ok no need to be a *** now iam just double checkin this way i know if i should buy the ecu for my car.Iam curious because out of no where it seems as if iam losing mid range power any clue on what would cause that?
Old Sep 22, 2007 | 08:11 AM
KRRZ350's Avatar
Not really, not if you count the idle operation as part of the EC programming.
The auto ecu in a manual will give a high idle for about 5 seconds whenever you shift into nuetral, at stoplights and sitting in traffic that 5 seconds of 1,500+ rpm's idle tends to be really annoying imho.
Old Sep 22, 2007 | 11:54 AM
icedout's Avatar
thanks man i thought there had to be something different between them.
Old Sep 22, 2007 | 01:51 PM
MadMaxSE-L's Avatar
Doggah Bite...
Maybe because now when you press on the gas, there is no torque converter to slip and provide some more gear reduction and let the engine spin up a little, so it seems like the car isn't pulling as hard? BUt trust me the 5spd is WAY quicker, and alot more fun to drive
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
bernyp
Oct 2, 2015 10:10 AM
