Please Help Car starting problem!!!!!!!
Old Sep 23, 2007 | 05:51 PM
gtmuggs's Avatar
I dont know if the clutch sensor switch is causing the car to have the start problems or not, at times ill get in and the car a start right up and other times its like i have to press the clutch hard to the floor or either try to press the clutch slowy to find that sweet spot the car starts. at first the problem was ok but now its getting worst and im spending 5-10 mins before the car starts also i put a new starter on about 80,000 miles ago but is there a way to test the starter? any info is helpful
Old Sep 23, 2007 | 06:27 PM
KRRZ350's Avatar
Faulty ignition switch is very common, however it really sounds to me and you that it is the clutch pedal safety switch, but just to verify, this didn't start after a clutch change correct?
vq35de.com, follow the links to your fsm, there is testing and adjustment procedures for the clutch switch located in the CL (clutch) page 4 of 11. Also, in the EL section there is mucho specifications for the starting system..............
Old Sep 23, 2007 | 06:31 PM
gtmuggs's Avatar
Thx for info
how often does the clutch saftey switch go bad, i do have 214,000k on the car
Old Sep 23, 2007 | 06:32 PM
gtmuggs's Avatar
the clutch change
actually i did have the clutch changed out last yr and it may have started after but it could of been so minor that i didnt pay it any attention!
Old Sep 23, 2007 | 07:08 PM
Big EEEE's Avatar
I'm betting on a bad ignition switch. I used to pound on my clutch and turn the key thinking the clutch switch had an imtermittant problem...finally, I held the key in start position and hit the clutch a few times and nothing happened which meant the ignition switch was bad. In otherwords, I could hold the clutch pedal down and steady and try to crank the car and sometimes the ignition switch would make contact and sometimes it would not. When I took the ignition switch out and apart, a small gap had eroded into the copper peice in the switch and I was able to form the copper to make reliable contact.
Old Sep 23, 2007 | 07:15 PM
gtmuggs's Avatar
sounds like it could be the case
thats exactly what i am used to doing is there a way to test the ignition and how hard is it to pull the ignition switch??
thanks for the info
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
Gsantos79
Aug 8, 2015 07:41 AM
