Transmission & Front Axle Shaft Problems
Old Sep 24, 2007 | 08:26 PM
JRevsMax's Avatar
My transmission was recently rebuilt about 6th months ago. Now i have taken it back because it was shifting really hard. They said that transmission went to crap and the front axle shafts were broken. They said that the transmission breaking had to do with the axle shafts breaking. Would this by true, or are they just trying to cover up their mistake? Has this happened to anyone?
Old Sep 24, 2007 | 09:09 PM
KRRZ350's Avatar
They are just trying to cover up their mistake unfortunatly, it's so much wiser to just put in a low-mileage (carfax the vin) junkyard tranny from car-part.com
Old Sep 24, 2007 | 09:15 PM
JRevsMax's Avatar
What would have caused the axle shafts to break then? And its under warranty so I would loose even more money if i went and baught another tranny.
Old Sep 24, 2007 | 09:26 PM
vqmaxman's Avatar
I am positively sure that they wrecked your tranny and I would have the copy of the receipt of where ever you got it fixed then take it to your lawyer and hopefully he will get some money out of them. I know that if your axles are bad and they have lost lots of grease your car would make grinding and grudging noises. It's rare that the axle locks up and so does you tranny and that's if the grease was totally gone and you where beating on it.
Old Sep 25, 2007 | 02:55 AM
dgeesaman's Avatar
Maintenance Monster
Hard shifting is sometimes caused by something breaking inside the tranny and the pieces getting in the way of the internal shifter mechanism.
I don't see how axle problems would cause something to break inside the tranny though. It seems highly unlikely. Fishy, really.
Dave
Old Sep 25, 2007 | 07:24 AM
KRRZ350's Avatar
^^^I think he's auto.........
Old Sep 25, 2007 | 12:58 PM
JRevsMax's Avatar
Yeah I am auto unfortunatly. Would that make a difference?
Old Sep 25, 2007 | 01:46 PM
KRRZ350's Avatar
Yes, mainly in that broken peices getting in the shift rails or stuck in the shift mechanism's are irrelevant because you don't have those things, and also if you were a 5-speed a rebuild is the way to go because our 5-speeds suck ball's and chances would be high that the junkyard one would be on it's way out, however auto is a completely different story, re4ofa or whatever it's called tends to hold up pretty good for the most part, and when they do crap out the most common thing that I've seen is the lock-up tourqe convertor locks up at idle and stalls the car. But regardless, that tranny shop should honor there warranty, my advice for the junkyard tranny was if they don't hold there end of the warranty you should take that route. Another suggestion though is if they are really going to try to screw you and you don't want to experience the joy of putting in an auto trannsmission yourself, or don't have access to the workspace and tools required, maybe you could work something out with them and suggest the alternative of them supplying and installing a used one for free, if they really are ****heads than offer to supply the tranny, hell if you were anywhere near me I have a few auto's that I'd give to you for a case of beer
Old Sep 25, 2007 | 02:39 PM
JRevsMax's Avatar
They have agreed to do it under the warrenty. they are just charging 300 to replace the front struts. What if i bring you two cases of beer and you 5 speed swap for me
Old Sep 25, 2007 | 03:22 PM
KRRZ350's Avatar
Hahaha, two cases of beer once a week for the next year maybe That's awesome though, I was pretty worried they were going to try to screw you
Lakersallday24
Nov 7, 2024 07:31 PM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
PH98I30
Aug 20, 2015 04:25 PM
