so finally got my H.ID's
Old Sep 24, 2007 | 10:15 PM
xkazik's Avatar
now one of my headlights is higher then the other .. how to aim them both to the same level help plz =)
Old Sep 24, 2007 | 10:18 PM
bkmax98's Avatar
this happen to me also, here :
You'll see 2 long screws, they have a black plastic end on them that is about 3cm long. 1 of them is to aim it up and down and the other is to aim it left and right. i recommend you use a ratchet tool to aim your headlights. Each headlight has 2.
Old Sep 25, 2007 | 08:08 AM
xkazik's Avatar
oo ok thx man =)
Old Sep 25, 2007 | 08:13 AM
xkazik's Avatar
did u use like a wall or something to aim them ? how did u know they are good
Old Sep 25, 2007 | 08:23 AM
udienow's Avatar
.... park in front of a wall at night... turn the aimer that is coming out of the headlight inside the engine bay until you get the desired results... its extremely ez. I suggest aiming them real low, mine are pretty low and ppl still flash me once in a while. People dont like HID kits, and I guess I cant blame them its rather bright and scattered.
Old Sep 25, 2007 | 09:12 AM
Elevated_Maxima's Avatar
Does anyone have a link for H.I.D. install? I am interested, I'd like to find out how hard/easy it is, and if it is really that beneficial.
I haven't found anything yet on how to install one, or where to install the power packs.
Old Sep 25, 2007 | 09:19 AM
xkazik's Avatar
well it depends how much you would liek to spend at the H.I.D kid .. i woud this while ago when i wanted to buy mine http://www.xenonking.com/installation.html . Never bought mine from there tho .. dindt want to spend that much money on mine . still in school and paying my bill lmao .. i got mine from a local store for 120 Banbo HId kid . im pretty happy with it .. but the installtion isnt plug and play . The guy explained to me and then i got it .. so if anything i can help u if u interested in them
Old Sep 25, 2007 | 09:30 AM
xkazik's Avatar
any one knows with of the two screws aims it lower/higher ?
Old Sep 25, 2007 | 09:50 AM
CHINO22's Avatar
I have a 2000 but it sould be the same i hope..far left or right should be for up & down and the inner ones are for left and right...Stay about 10-15 feet back from the wall..
Old Oct 13, 2007 | 07:33 PM
5StarMaxima's Avatar
which HID kit did u buy?
Old Oct 13, 2007 | 08:52 PM
xkazik's Avatar
Banbo hid kit 8000k
Old Oct 14, 2007 | 08:17 AM
99Maxima929's Avatar
Would a relay harness/kit make HIDs any brighter? This is a pic of what am talking about. Anyone use one?
http://cgi.ebay.com/HID-Fuse-Relay-W...QQcmdZViewItem
Old Oct 14, 2007 | 09:11 AM
DrTySOUFMaX23's Avatar
can u post some pics? i would like to check em out if u dont mind!!
Old Oct 14, 2007 | 10:41 AM
alcatranz518's Avatar
* - A little off topic, but somebody had to do it.
The 'standard' is about 25 ft. from a wall, garage door, etc. Just make sure you are a completely level surface from your car to the perpendicular surface. Your lights should be aimed at the 90 deg. angle where the wall/ door and the floor/ ground meet. Some people use a little shorter distance, but 25 ft. is the standard. (Keep in mind you will have some light scatter since you do not have projectors, but the glare will still be controllable to an extent.)
I have had Cefiro housings for about 2 years now, so unfortunately I cannot answer which screw is up/ down for you. Search it in the free search, its tucked away here in the forums somewhere. If not, someone wil chime in with here I'm sure, most everyone on here are very helpful.
BTW, how do you like your HIDs? I have a "Tenon" 4500k Bi-xenon kit from Ebay installed in my Cefiros without projectors (aimed a little down of course for courtesy for other drivers.) I love them! BIG difference over Silverstars! Cuts right through the fog and rain.
Old Oct 14, 2007 | 11:46 AM
xkazik's Avatar
Yea man even without the projectors the H.I.D's are really good .. just make sure u aim them down so u dont blind ppl .. when you aim them down u get that nice whole streen view lmao and so far even the police didn't get bother about them by my house and thats something new =)
DrTySOUFMaX23 the only picture i have of them is in my signature . you want the picture of the car aiming at the wall ? or picture like the one on my sig?
Old Oct 14, 2007 | 11:49 AM
xkazik's Avatar
HID Fuse Relay Wiring Harness i think that doesnt do any difference .. from what i know in some cars u need the HID Fuse Relay Wiring Harness to make the H.I.D to work at all that what it said in my hid manual , there was an example showed with it
Old Oct 14, 2007 | 08:21 PM
96blkonblkse's Avatar
hey guys i got a quick question, didnt want to make another thread, i dont think it warrents one. I got an HID plug an play kit. well i hoooked everything up and they dont work..like when i turn them on the initially come on then go off right away..if i put the high beams on as soon as i turn off the high beams they come on and go off. It is just a single-xenon..i dont know what is wrong whether it is the ballasts or something on my car. The normal headlights work fine though. Would a relay kit help? Maybe i should add: with the original 15AMP fuse they wouldnt even turn on for me right now..i put in a 20AMP and they turned on but went off right away. If all the automotive stores werent closed i would try a 25-30AMP. seems kinda risky on stock wiring seeing how thin it is, but i guess it only draws as much or more current on start up then draw less once there on.
maxima297
Sep 30, 2015 03:32 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
