Unique Problem With KS (Detailed Pics)
Old Sep 26, 2007 | 06:50 PM
tc97max's Avatar
I have read all the threads I clould find about the knock sensor and I know these questions get repetative but mine is different. I have a green sensor pluged into a green harness with two wires comming out the end that is mounted in the way of reaching into the crevice to get to the KS. My question is what is this? Can it be removed as a whole and how? I can remove the sensor but that does not give me enough space. And is there a write up on how to remove the KS the hard way by removing the manifold(s)?
Old Sep 26, 2007 | 06:56 PM
f550maranello2's Avatar
thats the wrong wire.. ur looking for the one that goes under the manifold.. you can see it in the first pic...
Old Sep 26, 2007 | 06:59 PM
andrei3333's Avatar
If im understanding this correctly, the green connector does not allow ur hand to get into the hole, why dont u unplug the connector and try it like that ?
Old Sep 26, 2007 | 07:00 PM
truculent's Avatar
you got the EGR solenoid vacuum on the pic. I just grabbed it with my hand and pulled it up and bent the plate until its out of my way. Then I bent it back.
Old Sep 26, 2007 | 07:02 PM
tc97max's Avatar
No I still can barely fit my hand in there with the wire unpluged. Do you guys have the same thing?
Old Sep 26, 2007 | 07:03 PM
andrei3333's Avatar
yeah i got the same green connector on mine,
i just try to get someone with small hands to do it for u, much easier
Old Sep 26, 2007 | 07:04 PM
tc97max's Avatar
Oh OK I should have thought of that I will give that a try.
Old Sep 26, 2007 | 07:05 PM
andrei3333's Avatar
yeah my mom did it for me, took like 5 minutes, i just used a set of extensions to untighten and then retighten the bolt, thats all
Old Sep 26, 2007 | 07:07 PM
tc97max's Avatar
I ment the bending suggestion, but your right I will deffinatly still need some one with small hands.
Old Sep 27, 2007 | 07:17 AM
Double E's Avatar
Yep...remove that green plug to get to it. I used a set of nitrile gloves to get in there. That way the glove got shredded instead of my hand. (Went through a few pair.)
I also used an open ended wrench to get the torque on the bolt I needed when it came out & went back on.
I also used a swivel socket to place the new sensor/bolt in the hole. I added a piece of tape to it to keep it in place until the threads started.
Once the threads started, I got my right hand in there and was able to thread all the way down.
A couple of times, I lost the wrench in there too & had to get a magnet to retrieve it.
If you've read all there is available, then just don't forget to freshen up the metal/metal contacts to the KS at the other end of the harness.
As far as a write up on the manifold removal process, it would be lengthy just due to the gaskets, hoses & various connections that have to be made. While it's off, it would be ideal to get it cleaned up too. I imagine there are bolt torque requirements as well so may be a shop manual would be the best route?
Old Sep 27, 2007 | 08:31 AM
cardana24's Avatar
Blown
get some smaller hands/arms I never un hook that sensor when changing knock sensors.
Old Sep 27, 2007 | 09:52 AM
Ruthless's Avatar
buy the correct tools. Also, your intake manifold is leaking there. Consider reaplcing the "o-ring" thingy. lol. Its rubber and below the intake manifold. lol Had 1/2 hr of sleep last night... work in slow mo right about now....
Old Sep 28, 2007 | 02:26 AM
dblock1's Avatar
97' SE 5spd.
i have to replace my ks aswell im the owners manual from autozone it sais you must remove the upper and posibly the lower intake manifold. These people are saying you dont which is cool. I have a write up on removal of the upper and lower manifolds but the amount of work involved detered me from wanting to chang it myself at all!
Old Sep 28, 2007 | 05:53 AM
air_max's Avatar
This is besides the point, but what kind of camera did you use to take your pics? Pretty clear.
Old Sep 28, 2007 | 07:27 PM
19Maximus98's Avatar
The "O ring thingy" is actual the Intake Plenum Gasket. $5 part
Like it was said earlier, disconnect the green plug. Next get someone with smaller hands, sister, mom, girlfriend, and have then get there hand in there. You might want to place a piece of leather or rag over the green plug to protect your wrist from getting slashed.
Good luck
Old Sep 29, 2007 | 08:30 AM
andrei3333's Avatar
^ haha wrist slasher
i just imagined a new suicide option, by way of the Death KS valley hole
I would think it would be obvious to disconnect the green connector if its in your way...
Old Sep 29, 2007 | 11:57 AM
nhaven's Avatar
Duct tape the green plug and all the sharp edges in the surrounding area, so your wrist wont get cut up.
Old Jan 1, 2008 | 11:12 AM
alpimax99's Avatar
Where can I find the write up for this? I need to change the upper plenum gasket on mine also the knock sensor...
Old Jan 1, 2008 | 01:20 PM
L0R1DA's Avatar
I wrote this up a while ago when I did the KS on my 97 i30, I used a u-joint to manuveur under the UIM and had to unplug that green sensor as well, hope it helps...
http://forums.maxima.org/showthread.php?t=375570
If you remove the IM for this job you should be prepared to replace the gasket as well otherwise you will most likely develop a vacuum leak down the road.
Old Jan 1, 2008 | 01:57 PM
alpimax99's Avatar
was it an fed-spec or a cali-spec 97???
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
16_SR
Sep 7, 2015 06:47 AM
maxfever1987
Sep 6, 2015 06:20 PM
nbstriker10
Sep 4, 2015 04:26 PM
