want fast blinkers?
Old Sep 30, 2007 | 07:14 AM
NElsonAQuino's Avatar
want fast blinkers?
its easy.. just leave your car turned on for 20 hours so you dont kill your battery and turn on your hazards and KABAM... or you can just go down to your local gas station, go inside the convienent store, spend 2.99$ on a size 89 bulb and put them in the place of your stock bulb and BAM!! fast blinkers, lights still work without having anything being burned out and im not sure if it turns on your CEL because mine has already been on but its worth a try by someone else.
Old Sep 30, 2007 | 07:51 AM
MadMaxSE-L's Avatar
Doggah Bite...
Old Sep 30, 2007 | 07:54 AM
xkazik's Avatar
lol
Old Sep 30, 2007 | 07:59 AM
MadMaxSE-L's Avatar
Doggah Bite...
Hey, IIRC if you pull out one of your front blinkers, the rear on the same side will flash faster too!
Old Sep 30, 2007 | 09:03 AM
MorpheusZero's Avatar
I remember when I was like 5 I thought fast blinkers were AWESOME
Old Sep 30, 2007 | 09:41 AM
nsnrider's Avatar
Old Sep 30, 2007 | 09:47 AM
RA030726's Avatar
I'm nutty for Nissans
I just run synthetic blinker fluid.
Old Sep 30, 2007 | 09:50 AM
TurTLe*'s Avatar
how often do you flush yours? i flush mines twice per each muffler bearing replacement.
Old Sep 30, 2007 | 10:02 AM
bwinter7's Avatar
I think you're only supposed to do it when you're cleaning the jets on your carb.
Old Sep 30, 2007 | 10:03 AM
EnervinE's Avatar
i has college
I just flush mine when I start to see rice in the fluid.
Old Sep 30, 2007 | 11:16 AM
shissqbob's Avatar
Amount of gas used for this mod: $65.00
Increase of carbon monoxide gas floating around: Some dead brain cells.
Letting the car idle for 20 hours: Just some more wear and tear on the car.
Super fast blinking turn signals: Priceless
For everything else in life, there's something wrong here.
Old Sep 30, 2007 | 11:54 AM
markd248's Avatar
What kind of fluid did you run during the break-in period? I heard we weren't supposed to run synthetic blinker fluid for the first 5000 miles I believe.
Old Sep 30, 2007 | 12:06 PM
Stardust's Avatar
F---ing Kangaroos
I was here.
Old Sep 30, 2007 | 01:14 PM
EnervinE's Avatar
i has college
Nissan used synthetic blinker fluid from the factory in all 4th gens. Whoever told you that is FOS.
Old Sep 30, 2007 | 01:20 PM
NeWyoRksPLaYaZ's Avatar
l0o0oo00oo00o0ol
Old Sep 30, 2007 | 04:15 PM
wuzzy's Avatar
only civics want fast blinkers
Old Sep 30, 2007 | 04:16 PM
Nissan 6's Avatar
no
Old Sep 30, 2007 | 04:56 PM
EnervinE's Avatar
i has college
Um, no. Fast blinkers make your car faster.
Old Sep 30, 2007 | 04:58 PM
99BlackMaxMS's Avatar
When I added my synthetic fluid mated with my LED blue blinkers, I gained 20 hp to the wheels y0!
Old Sep 30, 2007 | 05:01 PM
Crusher103's Avatar
what was the point of this? every time i see fast blinkers I think the car is not well maintained or just POS
Old Sep 30, 2007 | 05:03 PM
VANGtastic97's Avatar
poor guy. haha
Old Sep 30, 2007 | 05:05 PM
Gismo-T's Avatar
B!tch We Got a Problem
Just tried the mod...only gained 5 hp...didn't use synthetic fluid...
Old Sep 30, 2007 | 05:21 PM
markd248's Avatar
Oh **** really? Alright well I guess thats what my check blinker light (CBL) codes are for, anyone know what I should replace to fix this problem. I'm already going to buy new blinkers and the master blinker cylinder. Will I need new blinker lines for the fluid too?
Old Sep 30, 2007 | 05:25 PM
get some SS braided lines, they give you some increased blinker response
make sure they're teflon coated though, you REALLY don't want them to blow out in a few years and be without indicators
Old Sep 30, 2007 | 05:44 PM
KRRZ350's Avatar
I usually just do it at the same time as the flex capacitor volume relearn procedure.
Hey guys, just so you know, Amsoil now makes a 600* boiling point blinker fluid that is safe to use with our anti lock blinker systems!
Old Sep 30, 2007 | 07:01 PM
G4nismo's Avatar
Old Sep 30, 2007 | 07:06 PM
Gismo-T's Avatar
lmao...
Old Sep 30, 2007 | 07:16 PM
bkmax98's Avatar
you dudes are soooo mean. lol
Old Sep 30, 2007 | 07:44 PM
i30krab's Avatar
After reading this thread I can't stop blinking!
Old Sep 30, 2007 | 07:56 PM
Gismo-T's Avatar
LQQks like you've tried some synthetic fluid too.
Old Sep 30, 2007 | 08:49 PM
G4nismo's Avatar
BAM!
Old Sep 30, 2007 | 08:52 PM
Fr33way™'s Avatar
Wild for Width
Um, the bulbs weigh 2.5 ounces a piece. They have been gone...
Old Oct 1, 2007 | 12:18 AM
wat?
Old Oct 1, 2007 | 02:38 AM
tvis's Avatar
Old Oct 1, 2007 | 08:08 AM
DomoMaxima98's Avatar
LMAOOOOOOOOOOOOOOOOOOOOOOOO!!!
*DOA*
Old Oct 1, 2007 | 09:56 AM
nexgenmax's Avatar
R34
It happened that I replaced a blinker bulb with the wrong voltage bulb, then blinker blink faster. . This when I used to own honda accord.
Old Oct 1, 2007 | 01:22 PM
markd248's Avatar
Will I notice a better response from the turn signal stalk due to the upgraded lines? Also I heard Stillen's kit is okay, but from what I've heard Silverstar is in the works of making a kit for the 4th gen, should I wait for that one. Also I was planning on getting new upgraded bulbs for better response. Will the new offset of the bulb's require new taillights? I think I'll get some altezza's, i heard they add a lotta horsepower and turn signal blinks per minute.
Old Oct 1, 2007 | 01:30 PM
XeroX's Avatar
Hella internets
How do you get slow blinkers tho? i heard this is the new thing...anyone know?
maybe some heavier weight dyno blinker oil? when mine blink to fast i kinda burn my stock lower weight....
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
