2nd sensor location
Old Oct 2, 2007 | 04:18 PM
d3v0's Avatar
2nd sensor location
Where is the second sensor located on the '99 max? if anyone knows of a diagram or a very good answer that would be most helpful. the reason why i am asking is because i need to replace that one cause it reads high voltage or something. anyone have anything?
Old Oct 2, 2007 | 07:21 PM
VQ30DETT's Avatar
what kind of sensor?
Old Oct 2, 2007 | 07:23 PM
MadMaxSE-L's Avatar
Doggah Bite...
No ****
Old Oct 2, 2007 | 08:50 PM
67whitegoat's Avatar
The rear heated oxygen sensor (Rear HO2S) is after the catalyst. Look under the car and you can see it.
Old Oct 3, 2007 | 05:29 AM
heynow's Avatar
oh...i thought you meant the one in the clock that senses seconds.
Old Oct 3, 2007 | 06:43 AM
NmexMAX's Avatar
dot dot dot ...
Are you Fed or Cali spec?
Old Oct 5, 2007 | 03:59 PM
d3v0's Avatar
i think cali, thats with no O2 sensor between the cat and resonator pipe right? cause i dont have a O2 sensor between those two. i only have 2 on my y-pipe and 1 on each exhaust manifold. i need to replace the second one which ever one that is. all it says on the description of the code is number 2 O2 sensor high voltage. all i want to know is where the second O2 sensor its talking about where it is located.
220k+ A32
Sep 11, 2015 02:18 AM
