how do you know when your car is misfiring
Old Oct 3, 2007 | 07:16 PM
xkazik's Avatar
how can u tell?
Old Oct 3, 2007 | 07:22 PM
mastere954's Avatar
you hear it bogging out and u feel the car jocking a little bit..
Old Oct 3, 2007 | 07:32 PM
MadMaxSE-L's Avatar
Doggah Bite...
If it is a slight misfire, you may not feel much at all. It just feels kind of like you are getting on and off the gas really fast. The worse/more it's misfiring, it will feel like you are letting off/getting on the gas more and more. Also, the faster the engine is spinning, probably the smaller amount of time between pulses...
Old Oct 3, 2007 | 07:34 PM
clh288's Avatar
when the check engine light says so.
Old Oct 3, 2007 | 07:41 PM
made in china's Avatar
Depends on how bad it is misfiring and what is causing it. A bad O2 sensor can cause to car to misfire because it will run way too rich. In this case, the car idles slightly rougher, and you can hear a "putt___putt_putt_________putt___putt" kinda sound from the muffler while the car is idling. However, other causes of misfire may give you a misfire at certain RPM's or certain load, etc. The ECU should detect it eventually and give you a code.
What are your car's symptoms?
Old Oct 3, 2007 | 07:43 PM
MadMaxSE-L's Avatar
Doggah Bite...
Misfire will not always illuminate the CEL
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
yat70458
Aug 3, 2015 01:16 PM
