From reading posts on this site it seems like the kit includes:
4 struts and 4 springs
boots for all 4 struts?
bushings for both rear struts?
For now I want to replace everything on the suspension that requires removal of the springs. I will hit the tie rods, control arms, steering rack, etc in a month if I see they need replacing. From my readings this is what I decided on.
ILK246 Tokico Illumina 4 Struts and 4 Springs package $524 at performancepeddler
so I need to get:
KYB front strut mounts with bearings, boots, and bumpstop
gaskets for all 4 corners?
Please let me know what I need to add to replace everything on the suspension that requires removal of the springs. Let me know parts numbers if possible. Correct me if I am wrong on what is included. Thanks!
so I need to get:
Well, I got mine about a year and a half ago and it came with the adjustable struts, and springs and nut hardware to install them on the mounts as well as the adjusting key. Unless they have changed what you get I used the factory bump stops and just cut them. The boots I reused as well.
Quote:
already tried that route. If you read my post you would see that the info I have is from searches. Just trying to clear things up.Originally Posted by Kevlo911
Search and look in the stickies
