95 maxx blowing massive fuel smoke out tailpipe
Old Oct 9, 2007 | 05:15 PM
THEJEFFERATOR's Avatar
ok... the car ran fine, i got gas and drove 10 miles to work and parked the car. 9 hours later, it barely started and after it did it was bellowing raw smelling fuel smoke from the tailpipe. not a little bit, a cloud. no codes, i did the seafoam thing, inj. cleaner, swapped maf, swapped coils ( because i had a few extras ) now im thinking it could only be the pressure reg or one or more stuck injectors. i will do a leak down test soon. anything else i should try ? it is definatly raw fuel, not running rich like a sensor would cause. i think it's getting an overwhelming amount of fuel somehow.
thanx
Old Oct 9, 2007 | 05:36 PM
pmohr's Avatar
No more Maximas...
Then it could be a clogged fuel return, faulty FPR, or injectors stuck wide open. Pull out the injectors and crank the car a few times, see if any of them are stuck open.
Old Oct 9, 2007 | 05:47 PM
when i get the chance, i'll do the leak down test. that should prove the leaking injector possability ? id like to check what i can before pulling the top of the intake since pulling the injectors would only work on the front three. where does the fuel return system run to, directly to the tank or through any evap systems etc. ? thanx
Old Oct 9, 2007 | 05:50 PM
pmohr's Avatar
No more Maximas...
Well you won't lose compression through the injector, so a leakdown won't really tell you anything, unless the walls have been so washed down with fuel that the rings started gouging them up or something.
If your symptom is way too much fuel being delivered to the combustion chamber, why are you doing a leakdown?
Old Oct 9, 2007 | 05:57 PM
sorry, guess i didnt specify... fuel pressure leakdown test, not compression. inserting a pressure guage inline between the fuel filter and the rail.... a rapid loss in pressure should indicate a leak somewhere in the path to each cylinder.
Old Oct 9, 2007 | 06:04 PM
pmohr's Avatar
No more Maximas...
Ah, gotcha. That should indeed point out the issue in short time. I believe fuel pressure should remain in the lines for a few hours after you turn the car off, so it will bleed down, but not quickly.
Old Oct 9, 2007 | 06:17 PM
96blkonblkse's Avatar
Yeah the FP will stay in the lines for quite a long time before it will dissapate, all of those who have done the fuel filter will know this LOL.. God i thought i emptied all the fuel out of the lines, but due to my lazyness i received about 70PSI of fuel in the face..yes it is as funny as it sounds..of course after the fact.
If you check the FP should very slowly go down, but it would probably takes hours on end.
Old Oct 9, 2007 | 06:25 PM
true,.... been there. if you saw the way this thing is dumping fuel, it shouldnt take long ! besides, between pulling the fuse and running it dry days ago and im banking on a big leak somewhere.... i shouldnt get wet !!!
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
