AWD conversion using G35x drivetrain
Old Oct 10, 2007 | 07:19 AM
Qbridg3's Avatar
I saw this brought up a couple of times here. Is it even possible since the G35x is longitudinal? Has anyone looked into it?
Old Oct 10, 2007 | 09:21 AM
JtzMax's Avatar
Whatchyou say?
are you smokin crack ??? not even an option, buy a G35 or Skyline ...
EDIT: sorry ... in a rotten mood and it's not your fault! sorry for the dumbass reply!
Old Oct 10, 2007 | 09:23 AM
pmohr's Avatar
No more Maximas...
Well it's a direct bolt up for the most part, just need the rear subframe from the G35x, and a half-size aluminum racing radiator for a CRX B16A swap, because the motor won't clear the stock rad.
Only problem is the G35x only comes in auto, so you'd have to get a trans from an R34 GT-R to have the 6MT.
Don't mind JtzMax, he's not up to date on the latest swap info.
Old Oct 10, 2007 | 09:29 AM
JtzMax's Avatar
Whatchyou say?
sorry ... a bit upset this morning.
What about drive line? where are you gonna put a drive shaft and how will the G35 rear end clear the fule tank? I shouldn't say it "can't" be done ... but is it really worth it? It'd be expensive as all get out if you do it, so it may be more feasible to get a G35x for the same or cheaper money.
Cheers!
p.s. how much is this total project worth -vs- how much will it cost?
Old Oct 10, 2007 | 09:31 AM
chillin014's Avatar
on mine i just bought a rear clip from a gtr skyline welded that hoe on there and called it a day.
Old Oct 10, 2007 | 09:34 AM
slinky87's Avatar
a AWD maxima would be a sleeper but how much weight is it adding?? I would say **** it and convert it to full RWD maybe a LS1 with a turbo....
Old Oct 10, 2007 | 09:38 AM
pmohr's Avatar
No more Maximas...
Cheers!
Well the 'exhaust' tunnel is more than large enough for a driveshaft, and if you use the R34's tank, the rear end/driveshaft will clear easily. If you can find a wrecked G35x, the swap can be done for <$3000, which I think is more than worth it.
Now chillin014, he went with the BNR-34 rear clip, which is pricey and not as easily available in the US. IMO, not exactly the smartest move, but as you can see the swap is relatively easy, compared to an Integra or such, whose chassis never came RWD from the factory as ours did in Japanese/Swedish markets.
Raxles will make custom axles to fit your hubs on the front and either the G35x auto trans or the R34 6MT, and honestly that's the hardest thing about the job, is finding those axles. I'd suggest giving them a call and seeing if those are still available from them as the first step to the project.
Old Oct 10, 2007 | 09:45 AM
JtzMax's Avatar
Whatchyou say?
I knew that the 1st gen Max's came RWD .... but had no idea that they came that way later in life. With the G35x trans ... is there any retroing that needs to be done? I agree the exahust well is deep enough for a drive shaft .... but then where do you hang the exahust? Under the shaft is the only place I can think to do it .... and then, it'd be a tight squeeze I am guessing.
Old Oct 10, 2007 | 09:49 AM
pmohr's Avatar
No more Maximas...
The exhaust can hang over top of the driveshaft (a la BMW, those ****ers), you could do side-exits, or get Nissan Cedric floorpans which has an area to route the exhaust piping.
Old Oct 10, 2007 | 10:09 AM
chillin014's Avatar
okay i lied. i bought a gtr FRONT clip and just reversed everything so i could run fwd in the rear if you know what im sayin.
Old Oct 10, 2007 | 10:14 AM
pmohr's Avatar
No more Maximas...
GT-R clips are still pretty damn expensive, G35x's are at least available in the US (oops, assuming you're in the US) so no hassles with shipping the parts overseas.
Old Oct 10, 2007 | 10:17 AM
chillin014's Avatar
yeah im in the US. i just got hook ups like that. i got a front mounted motor and then a rear mounted one to run the "RWD"
Old Oct 10, 2007 | 10:36 AM
97SMG's Avatar
Snawomes! Now that I know its possible, im going to order a G35 rear subframe and a quad turbo set up. Hopefully Harry can overnight it all from Japan for me. Anyone know where I can get custom piping? I want to run all four snails out of the trunk
Old Oct 10, 2007 | 11:35 AM
maxima985spd
I heard its about a 2 day swap and doesnt take much fabrication at all. just like pmohr said its a direct bolt on. typical cost of the project is about $2,000 which is pretty cheap.
Old Oct 10, 2007 | 12:15 PM
Qbridg3's Avatar
You all are no fun. I only brought this up because one or two of you all did.
Old Oct 10, 2007 | 01:26 PM
maxima985spd
Pr00f of where it was brought up
Old Oct 10, 2007 | 01:33 PM
pmohr's Avatar
No more Maximas...
http://forums.maxima.org/showpost.ph...01&postcount=8
Originally Posted by NmexMax
Put pink dots on it, w/ 22" wheels. Convert AWD (driveline from G35x), and use an RB series engine.
I was hoping NmexMax would get in on this thread
Old Oct 10, 2007 | 01:36 PM
maxima985spd
yea i would think since nmexmax has done it before
Old Oct 10, 2007 | 01:59 PM
chillin014's Avatar
good point. only those who have done the swap should be contributing with their advice. and i'm also here if anyone wants to know about swapping in a fwd ls1.
Old Oct 10, 2007 | 02:06 PM
DrunkieTheBear's Avatar
Turbo'd Saab
I would like to see detailed pics of this when someone actually does this and not just talks about it. so subscribing...
Old Oct 10, 2007 | 02:23 PM
chillin014's Avatar
omfg
Old Oct 10, 2007 | 02:39 PM
JtzMax's Avatar
Whatchyou say?
Ok ... so you have 2 engines in your Maxima? WTF mate? lol I don't understand what it is that you did here. Did you just convert your FWD to RWD ???? Or ... did you actually make it AWD? Please clear this up for me (us).
As for making it AWD, you'll have to get a transfer case like in the G35x or GT-R (R32 - R34). That is gonna add weight, so you may consider bummin up the HP while your at it too.
Cheers!
Old Oct 10, 2007 | 04:25 PM
f550maranello2's Avatar
2 engines > 1 engine...
Old Oct 10, 2007 | 04:41 PM
chillin014's Avatar
lol................
Old Oct 10, 2007 | 04:45 PM
maxima985spd
4WD > 2WD
Old Oct 10, 2007 | 05:07 PM
Kevlo911's Avatar
Kevlo for President
Wow I guess I should dedicate more time to the org instead of HW to close this type of ****
KabirUTA13
19
Oct 17, 2015 02:15 AM
Calabar
Oct 5, 2015 09:57 PM
hot04
Sep 18, 2015 06:14 AM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
