Wet floor board, any suggestions?
Old Oct 10, 2007 | 08:25 PM
PhatBastard's Avatar
The front passenger floor board of my '95 is sopping wet. I wanted to check and see if anybody has experienced this before I tear into it this weekend.
My guess at this point is that the A/C condensation is either backing up due to a plugged drain or there is a hole in some sort of drainage ducting near that area.
Anybody happen to know how the A/C condensation is collected and drained to the outside of the car?
Old Oct 10, 2007 | 08:30 PM
MOHFpro90's Avatar
My friends car(non maxima) would actually regurgitate water out of the feet AC vent. I think it hated me though, or maybe it was the flip flops; it never seemed to spit on me when I had shoes on...
Check the obvious spots before really digging for the location. GL with not getting any mold too.
Old Oct 10, 2007 | 08:32 PM
mansurxk's Avatar
i believe there's a technical service bulletin (TSB) on this. common problem.
Old Oct 10, 2007 | 08:40 PM
Where can I find the TSB? It's been awhile since I've been on this board.
Old Oct 10, 2007 | 10:57 PM
White Shadow's Avatar
Still chugging along...
I have a '92 Stanza that did the same thing from day 1. It was the air conditioner. The A/C was dealer installed and they left something loose or something and every time I turned left sharply water would splash out on the passenger side floorboard. It will ruin your carpet and backing pretty quickly if you don't get it fixed and keep it dry.
Old Oct 11, 2007 | 12:11 AM
96blkonblkse's Avatar
Yeah i had a problem similar but it was a rear door seal that leaked water in and it went all underneath the pass seat and soaked all the carpet. It was fun i basically tore out all the carpet, both seats put a heater in side the car and cleaned all the metal with a mix of bleach and hot water + a rag. put all the underlay in the washer (lol yes i wrecked the pump lol), and let it hang dry in the basement..took me a good 2 days but it was worth it.
Old Oct 11, 2007 | 12:47 AM
Here you go. Hope this helps....
http://forums.maxima.org/showpost.ph...0&postcount=32
Old Oct 11, 2007 | 06:19 AM
cardana24's Avatar
Blown
The AC drain could be blocked.
Does it smell like coolant in the car? Dab the liquid with a paper towel to see what color it is. Your heater core could be taking a dump.
Old Oct 11, 2007 | 06:38 AM
ROCKART's Avatar
wants an I35
the AC moisture in the drain is dripping water from condensation. the runoff wouldnt smell like coolant if it was in fact the AC drainage.
if the water smells like coolant you got a whole other problem.
Old Oct 11, 2007 | 07:28 AM
cardana24's Avatar
Blown
I know. I was suggesting two different problems.
Old Oct 11, 2007 | 07:35 AM
ROCKART's Avatar
wants an I35
ahh. my mistake. its still pretty early
Old Oct 23, 2007 | 05:49 PM
Thanks for all the replys. I wasn't getting e-mail notifications for some reason is why I haven't been back sooner.
It is definitely the drain for the A/C condensation and it's leaking at the firewall.
TSB says to pull the evaporator and shop-vac it and the drain tube.
Anybody managed to clean the drain tube in place without pulling the evaporator??
Like everything else on the Max, the end of the drain tube is in a very tight place on the firewall.
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
