all the .org links are broken in the how to section and such. google turned up nothing.
im pretty sure i know everything, but: what special tools do i need besides common sockets and an o2 socket. what size crush rings are needed?
a link to a guide or an equipment list would be infinitely helpful as i plan on installing today and doing a butt dyno test.
Theres a write up in here:Originally Posted by evil_spork
all the .org links are broken in the how to section and such. google turned up nothing.im pretty sure i know everything, but: what special tools do i need besides common sockets and an o2 socket. what size crush rings are needed?
http://forums.maxima.org/showthread.php?t=322569
If you'd read the site announcements, you'd see how to view old links... http://forums.maxima.org/showthread.php?t=537445Originally Posted by evil_spork
Quote:
oh sweet thanks for the flame/helpOriginally Posted by pmohr
what size crush ring is needed from the ypipe to the cat?
local kragen is out it seems.. the ones from header to ypipe are listed as needing 2 and in stock..
It's not a crush ring, it's a multi-layer metal. OEM ftmfw, they're cheap enough and much better quality, and most nissan dealers have them in stock. Use a propane torch to heat all the y-pipe to manifold bolts up, every once in awhile they snap, more so on the rear, and then it's a biotch to deal with, so always use heat.
Quote:
Really? When I got mine at the dealer they called it a crush ring gasket. Now, I'm sure the dealer could've been wrong, they have been before, but I've always heard people refer to them as Crush ring gaskets.Originally Posted by KRRZ350
Quote:
Y-manifold are crush rings, all other exhaust connections are two bolt multi layer gaskets.Originally Posted by markd248
Quote:
and this is what i got. i got 2 crush rings and a 2 bolt metallic flange gasketOriginally Posted by pmohr
Haha woops I misunderstood KRRZ350 since I didn;t read the post before his right. Oh well, continue on thread.
