Slight Shaking/rumbling randomly at idle
Old 10-14-2007, 11:47 PM
99MAXSE-L's Avatar
At a stop sign, red light, or just whatever, whenever im in D, i feel a slight shake/rumble that goes on and off ONLY in idle. Its getting me worried and i just dont know what it could be. The RPMs dont move or nething its just that i can feel it throughout the car. It does it some days and not other days. Kinda weird aint it ?
99MAXSE-L is offline
Old 10-15-2007, 05:57 AM
heynow's Avatar
test ur coilpacks
heynow is offline
Old 10-18-2007, 09:04 PM
SHADETREE95's Avatar
I was just gonna post the same problem on my 95. Mine comes and goes from time to time. It's like a drop in idle to where it runs rough.
SHADETREE95 is offline
Old 10-18-2007, 09:19 PM
andrei3333's Avatar
whats your idle at ?
andrei3333 is offline
Old 10-18-2007, 10:17 PM
f550maranello2's Avatar
might be the ignition coils..
or u have a leaky injector... i had the same problem
f550maranello2 is offline
Old 10-18-2007, 10:24 PM
99MAXSE-L's Avatar
my idle is at 1700 i think, i will take notice of it next time.
And r u talking ab out a leaky fuel injector?
Old 10-18-2007, 10:37 PM
jordandalley's Avatar
1700?? thats a bit high... umm.. about 1000rpm too high :P
jordandalley is offline
Old 10-19-2007, 05:50 AM
heynow's Avatar
99MAXSE-L, it's can't possibly be idling THAT high. Look again please.
heynow is offline
Old 10-19-2007, 10:30 AM
wiggafly808's Avatar
It can be - if his TB, IACV, and stuff is dirty, or his idle control screw is loose.
Mine was dirty and the screw was loose and the idle was up at 1700. =/.
wiggafly808 is offline
Old 10-19-2007, 10:52 AM
heynow's Avatar
yeah well, some of us actually PAY ATTENTION to our cars
heynow is offline
Old 10-19-2007, 11:35 AM
matrix11229's Avatar
How much vibration do you have in D ? While you don't have the vibration in D does it feels as smooth as in N ?
matrix11229 is offline
Old 10-19-2007, 11:36 AM
heynow's Avatar
what's your rpm while vibrating in "D" ?
heynow is offline
Old 10-19-2007, 03:24 PM
99MAXSE-L's Avatar
ok nevermind...it is around 1000, i dunno what i was thinking...
I have very little...it comes and goes, and its not even a vibration, its like a rumble.
Old 10-19-2007, 03:30 PM
andrei3333's Avatar
wrong if thats dirty the worst thing that happens is it idles LOW and as it hits around 500 rpm it bounces back to about 1500 or less and slowly lowers
Old 10-19-2007, 03:32 PM
andrei3333's Avatar
1000 is still high auto should be 700 +/- 50 this is spec
i cant think right now cause i just got off my new job and i am tired as hell, but the idle is the key, investigate what is causing it to be high - OR bad motor mounts maybe?!! duno
Old 10-19-2007, 04:35 PM
heynow's Avatar
just clean your TB & IACV, replace the gaskets and adjust the idle afterwards
heynow is offline
Old 10-19-2007, 05:41 PM
99MAXSE-L's Avatar
cleaned my TB durin the summer...
NOTE: when it does its weird *slight* rumble in D only...and not neutral....nothing happens to the rpms (it doesnt drop or anything)
Old 10-20-2007, 01:38 PM
Hmm, i guess then mine was just because the screw was loose.
I just threw them both out there because i cleaned them and tightened the screw at the same time.
Old 10-21-2007, 12:07 AM
99MAXSE-L's Avatar
anyone still know what i should do ?
Old 10-21-2007, 09:57 AM
cplichta's Avatar
Possibly motor mount, exhaust hanger can cause vibration as well.
cplichta is offline
Old 10-21-2007, 11:30 AM
Divewjason's Avatar
Mine idles anywhere from 750 to 1100.(Only gets to 1100 when automatic choke was engaged prior.) My car usually idles at 900 when it is warmed up. My friends at Pensacola Honda couldn't find anything wrong with it. One suggested that it just might have always done that although he said that Maximas normally idle at 750. Maybe I have a factory freak? lol.
Divewjason is offline
Old 10-21-2007, 12:36 PM
Spark plugs ?
Upper intake manifold gasket vacuum leak ?
Old 10-21-2007, 03:29 PM
thenextman's Avatar
Probably a misfiring ignition coil
I've experienced a very similar situation with my '99 Max and the problem only got worse over time. What started as an intermittent shake eventually became more pervasive over time and lead to loss of power and service engine soon lights.
With some research and a lucky code reader hit I was able to pinpoint the problem to a misfire in cylinder #5. Maximas are known to have ignition coil issues and it is usually recommended to replace all 6 at once, but since i had a good idea of which one was bad i got a new coil at Auto Zone and just replaced it today. It was a bit of a pain, but definitely do-able (i spent 60 to replace 1 coil rather than have the dealer replace all 6 for nearly a grand). The difference was immediately apparent after driving it around my neighborhood, my Maxima is rejuvenated.
This issue started out, more than a year ago, very much like your own and the problem would come and go, sometimes for more than a month at a time. I just wanted to let you know about my experience, hopefully it can give you some insight into your own. Good luck.
thenextman is offline
Old 10-21-2007, 03:36 PM
96blkonblkse's Avatar
Have you cleaned the IACV? I had a similar problem in my 5spd, whenever id come to a stop, my rpms would dip to ~500rpm the car would shudder a bit then they would go back up. Although it never stalled it didnt do it every time either, i cleaned the TB/IACV and ran some fuel system cleaner in there (BG 44K + 3M fuel injection cleaner) and it cured that problem.
Even if it is a slight miss fire there will be some variation in RPM. Id check the resistance on your coil packs, and while your down there check your plugs.
99's do have coil pack issues so i would definately check that out!
96blkonblkse is offline
Old 09-27-2010, 12:08 PM
PGB25's Avatar
same problem
i have been having the same exact issue, i did some research and found this, but i have antoher questions. Last night driving in the rain the shake/rumple was MUCH GREATER WHEN RAINING. Also this didnt happend before when i first press gas car like studdddering then going...WHEN gets to 2000 rpms its fine...any thoughts? I have a 95 auto
PGB25 is offline
Old 09-27-2010, 07:03 PM
99MAXSE-L's Avatar
its most likely your coil packs...
Old 09-27-2010, 07:23 PM
jefforai's Avatar
wow, and to think that my car had problems, i guess i got to change my coilpacks soon... i recently had a tune up oil change etc etc. and my car was shaking less... but i took a trip down to PA and my car felt like it was ready to fall. THIS THREAD has DEF helped me.
jefforai is offline
Old 09-27-2010, 07:26 PM
FallenOne's Avatar
..... Vaccum Leak.
FallenOne is offline
Old 09-28-2010, 06:49 AM
PGB25's Avatar
yea i think its a vaccum leak too...anyone have any thought what i should check for a vaccum leak
PGB25 is offline
Old 09-28-2010, 08:42 AM
Phromethius's Avatar
I had this exact same problem when I bought the vehicle used. LONG STORY SHORT. They had the car for over a month, tested every other sensor and replaced timing chain and all that. I had taking it to Firestone of all places for their cheap "lemon test". I was a car noob at that time. I had no clue what it could be. They said it looked like bad ignition coils but they didn't have enough time to narrow down which one. I took this info back to the dealer and they blew me off. After a month of fooling with it they called in their NISSAN GURU, some specialist from California, I'm in Texas, he took one look and said "Did you replace the coils?" they said no. New coils and rumble was gone. Although mine was bad enough of a misfire that I did see an RPM fluctuation but ONLY in idle in D. I agree with a lot of you all, check your ignition coils.
Phromethius is offline
Old 09-28-2010, 05:28 PM
PGB25's Avatar
I wanted to see what coil was bad so i swapped coil 1 with 6...and the problem got worst...so is the bad one 1 or 6 or both????any thoughts
PGB25 is offline
Old 09-28-2010, 05:44 PM
Joeker82's Avatar
Could be a O2 sensor also. For the rough idle...
Joeker82 is offline
Old 09-28-2010, 06:01 PM
Br0nz's Avatar
tells me more than one is prolly going you moved the bad ones to the same stroke! am i making sense to anyone else lol!
Br0nz is offline
Old 09-28-2010, 06:39 PM
jholley's Avatar
You cannot swap coils 1 & 6. You have them confused:
FIREWALL
1 3 5
2 4 6
RADIATOR
Before you swap any coils test them individually. With the engine running in park or neutral disconnect each seperate coil individually. If disconnecting that specific coil made the motor rumbling worse then it's good. If it made no difference then it's defective.
jholley is offline
Old 09-29-2010, 04:41 AM
Trini Boom's Avatar
FIREWALL
1 3 5
2 4 6
RADIATOR
He will not get the result he desires this way because when you place it into N, the shaking goes away. You have to start the car, pull up your emergency hand brake and shift into D. Make sure the car is not moving when your foot comes off the brake pedal. Once that's confirmed, go and disconnect them one by one. The engine will shake but you have to place your hand on top of UIM to feel for the extra shake. If you don't feel the extra shake when you disconnect a particular coil, then that's the one that's failing under load.
Trini Boom is offline
Old 09-29-2010, 08:21 AM
PGB25's Avatar
i meant to say i switched 2 and 6.....but i believe it is better to shift into d and put the e-brake on..i will do the test within soon...i will see what happend
PGB25 is offline
Old 09-29-2010, 11:47 AM
PGB25's Avatar
just did the test...everything seems to be fine...all coils work....anything else i can check for....i know i have a hole in my flex pipe...but i covered it up with a patch i got at pepboys...seems to be working...would THAT have anything to do with it
PGB25 is offline
Old 09-29-2010, 03:18 PM
Trini Boom's Avatar
Clean your IACV and TB.
Old 09-30-2010, 05:33 AM
PGB25's Avatar
got to clean them this weekend...another question idk if this is ok to do....i know i have a hole/warned out flex pipe..i try to cover it with so muffler wrap for now...do yu guys think it might be the o2 sensors since of that hole in flex pipe.??? if i unplug the 02 sensor can i do the same test as with the coils?
PGB25 is offline
Old 09-30-2010, 07:04 AM
jholley's Avatar
If the shaking/ rumbling only occurrs while in D then why was he testing the coils? A blown coil will cause a misfire in any gear. After flushing the transmission fluid yesterday I re-installed a defective coil I had on the shelve. It misfired and shook the engine in every gear.
If the shaking only occurrs in D then clean the intake:
http://forums.maxima.org/4th-generat...g-dummies.html
jholley is offline
Quick Reply: Slight Shaking/rumbling randomly at idle
