Possible place to run wires to cabin?
Old Oct 18, 2007 | 02:35 PM
EnervinE's Avatar
i has college
I'm looking for a place to run some wire from the engine bay into the cabin, and I found this hole. It's behind the driver's side strut tower in the engine bay. I labeled it in case the location is unclear.
Does it lead to the cabin (if so, where?) Or is there a better place to utilize? Outputting under the dash (near the pedals) would be ideal.
Old Oct 18, 2007 | 02:42 PM
pmohr's Avatar
No more Maximas...
Merlyn's A33B has a similar hole, when we fed the WB harness through there, it ended up in the wheel well (though this was on the right side, he ran his amp power wire through the driver side and said it was the same way). From there it was just a matter of getting through the grommet that leads into the cabin, it all ended up behind the kick panel.
Old Oct 18, 2007 | 02:52 PM
CRiME's Avatar
oem ftw!
To run my amp wire and ground wire to the 00vi, i used an existing hole near the center of the firewall. There is a rubber grommet type thing capping it off. Pulled it out and the hole works fine. It will work perfectly for you, it leads slightly above and to the right of the gas pedal. Pictures in this thread:
http://forums.maxima.org/showthread....rewall+grommet
Old Oct 18, 2007 | 02:57 PM
EnervinE's Avatar
i has college
That's PERFECT. Thanks a bunch.
Old Oct 24, 2007 | 02:33 PM
vilmaxima's Avatar
if that dont work for u(like for me) go to the left of that arrow where its the cutout to the master cylinder(5 speed) and drill a hole and feed it through, this worked for me
Old Oct 24, 2007 | 03:36 PM
f550maranello2's Avatar
^^^that it the best spot
conansriver
Sep 3, 2015 06:38 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
