Exedy OEM or 5th Gen Clutch setup?
Old Oct 18, 2007 | 03:17 PM
MaximA StyLeZ's Avatar
My Power mods are: 00vi, JWT ECU, Y-Pipe Back.
My question is whether I should go with the Exedy OEM from importrp for $140 shipped or the 5th gen setup for $200 shipped.
Here is another link for the Exedy from ebay: http://cgi.ebay.com/ebaymotors/EXEDY...7789QQtcZphoto
I ask because the exedy is listed as compatible with 00-01 maxima. Therefore, does this mean it has the same specs as a 5th gen setup or 4th gen?
What would be recommended? Or even maybe a Exedy stage 1, or is that unecessary?
Old Oct 18, 2007 | 07:11 PM
pmohr's Avatar
No more Maximas...
IIRC, the 5th gen OEM is exedy equipment.
Honestly I'd just get a 5th gen setup from Dave B...great guy, great prices, and can't really lose with OEM (I don't think he'll even sell that Key Value crap to an org member).
Old Oct 18, 2007 | 08:25 PM
yah.. I have the key calue crap in right now.. not coool at all
So what exactly would be the difference btw OEM 5th gen and OEM Exedy ? If they are the same kits, I guess the price jackup on the OEM from Nissan is due to the stealership effect ?
Old Oct 19, 2007 | 02:55 PM
mowgli29's Avatar
Horizontally opposed.
If I were you I'd get the 5th gen clutch, if not something a bit stronger. Depending on how you drive you might want something that can take more abuse...? IMO, stay away from the exedy on ebay. 200 is not expensive for a clutch, so at the very least get some genuine nissan parts....
I have y pipe back, UDP, lightweight flywheel and CAI. I just ordered a fidanza full kevlar 4 puck clutch.
I went with the kevlar since it can take craploads of abuse, will hold more than stock, and is still very streetable. Its not cheap tho...
just my thoughts!
Old Oct 19, 2007 | 04:40 PM
squishy's Avatar
I got a Luk clutch kit and it seems to be nice. My friend works at a speed shop and said they are awesome.
Old Oct 19, 2007 | 07:05 PM
just my thoughts!
If it's that aggressive, your tranny will hate you. There have been a lot of reports, stating that aggressive clutches will more than likely cause damage to our transmissions. (3rd gear blowout)
Old Oct 20, 2007 | 10:16 AM
Kevlo911's Avatar
Kevlo for President
Only the AE clutch is made by exedy...
I think regular 5th gen is NISSAN
http://kevlo911.ic3donline.com/image...p/IMG_1689.jpg
Old Oct 20, 2007 | 12:51 PM
So any ideas on whether the specs are the same with the Exedy / 5th gen setup ?
If so , it would make a lot of sense to just get the exedy for $60-70 less.
Old Oct 20, 2007 | 06:22 PM
skuccio's max's Avatar
Beast Mode!!!
I had a stock Luk clutch on my slightly modded Accord... ragged on it daily, chirped 2nd like nobody's business... it was like new when I pulled it out a year after putting it in (motor grenaded). They make good stuff.
Exedy is good business though, but I would go for the stronger clutch. U basically have a 5th gen motor now, might as well get the 5th gen clutch.
Do OEM 5.5 gen clutches work for us? I'm guessing no?
Old Oct 21, 2007 | 08:13 AM
Kevlo911's Avatar
Kevlo for President
AE clutch has a different part number than the regular 5th gen.
And 5.5gen won't work
Old Oct 21, 2007 | 03:47 PM
96blkonblkse's Avatar
I had the 01 AE clutch setup in my car before. Took all the abuse i could throw at it and held up good. Even tracked it a couple of times and it handled it fine. Id definaltey consider it again, considering my power mods, ive even heard a couple of the SC guys running the 5th gen clutch setup with no initial problems.
and yes running to strong of a clutch WILL cause tranny issues if you beat the hell out of it. These trannys are fragile as is lol..
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
maxima-junky
Aug 13, 2015 09:59 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
