VIS CF Hood help...
Old Oct 20, 2007 | 07:06 PM
udienow's Avatar
VIS CF Hood help...
I got a VIS CF hood installed, and the place that installed it said there was no way to fit the factory hood struts w/o drilling in it and they didnt wanna do that. Does the hood need modification to fit oem hood struts? Also the windshield squirters are too big to fit in the holes that came on the hood. Do I need to buy new squirters somewhere? Any info on this would be great...
thx,
Matt
Old Oct 20, 2007 | 07:48 PM
MrDicks95SE's Avatar
Offset Is Everything.
scrap the struts and use a hood prop. enlarge the hole for the squirters. done.
Old Oct 20, 2007 | 09:23 PM
pmohr's Avatar
No more Maximas...
With the stock struts (assuming they're good), chances are the hood will bend either when you close it, or when it's latched, since the stock struts are meant to hold up a good 20 lbs heaver than CF.
Old Oct 24, 2007 | 02:08 PM
vilmaxima's Avatar
you'll have to drill washer holes bigger unless u wanna get smaller ones and pmohr has a good point about the weight issue
Old Oct 24, 2007 | 06:07 PM
MaxSoRytVQ30's Avatar
i will buy your stock ones for $10
Old Oct 24, 2007 | 07:13 PM
mastere954's Avatar
if you are planning on making holes in that hood be very carefull because that fiberglass in the inner part of the hood is very weak. as for the water squirters, dont use a drill because the cheap clear coat on the hood will crack. Happened to my friend. use a screwdriver shapped file and grind the edges of the original holes slowly, very slowly, i did it and it worked perfectly.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
