Lower Oil Pan Removal
Old Oct 26, 2007 | 10:27 AM
clear-mind@180's Avatar
All -
My dear old 1996 Maxima (GLE) has developed a leak in the lower oil pan (I have verified this - it's not the upper ) So... How do I get the lower oil pan off? I know it's an RTV seal which at this point may as well be glue. How does one get the pan off?
Thanks in advance for any ideas -
PS - there is also a very slight leak at the OPS so I'm going to do that at the same time.
Old Oct 26, 2007 | 10:38 AM
kzoosho's Avatar
unbolt and pry . Pretty much straight forward and darn easy also. i just had to pull mine to modify it so yea its not hard at all.
Old Oct 26, 2007 | 11:57 AM
Dubbya's Avatar
VK56 Inside
I used a putty knife to gently break the RTV seal in a few places then it just popped off.
Old Oct 26, 2007 | 12:44 PM
Thanks - I got it off then spent the better part of an hour getting it all cleaned up (engine part and pan) for the re-seal.
Thanks again -
Old Oct 26, 2007 | 04:44 PM
f550maranello2's Avatar
you did get new front and rear seals right.. and did put RTV in the correct spots??
Old Oct 26, 2007 | 04:46 PM
nismology's Avatar
You sure it wasn't the oil pressure sending unit? In any case, the process of removal usually bends the lower pan slightly. I'd flip it upside down, place it on a block of wood and hammer the edge of the pan until it's straight again. Or as straight as you can get it...
Old Oct 26, 2007 | 04:52 PM
well the lower one can be bent but the upper one no way...
Old Oct 26, 2007 | 04:54 PM
nismology's Avatar
^ I don't understand why you posted that.
Look at the thread title.
Old Oct 26, 2007 | 05:03 PM
uhhhh.. oh yea.. thats what i get for using the computer while driving....
Old Oct 26, 2007 | 09:07 PM
Nopike's Avatar
That not only makes for posts that make no sense, it's also dangerous.
Old Oct 27, 2007 | 08:41 AM
i was stuck in on i290 in traffic i was board....
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
SusieQQ
Sep 9, 2015 12:14 PM
sdotcarter
Sep 2, 2015 09:53 PM
