engine trouble
Old Oct 29, 2007 | 08:20 PM
brasso's Avatar
engine trouble
my car sounds like a subaru wrx and has no power . I think its a missfire but the cel didnt come on, has any one ever had these symptoms and if you did what was the problem and how did you fix it.
Old Oct 29, 2007 | 08:28 PM
vqmaxman's Avatar
First, what year is your max if it's 99 check the coilpacks for misfires. I would also look at the fuel injectors and see if there clogged up and see if there causing the misfires. when you start your car does it have to crank alot then turn over would like to have more info.
Old Oct 29, 2007 | 08:42 PM
h22enjen's Avatar
I had a similar situation like this. One day, car sounded like a wrx and it was losing major power. The culprit... the coilpack on one of the cylinders were bad! so check your coilpacks. one or more isn't working correctly. You leave the car running and just unplug them one by one... if you hear an idle drop.. that means that coilpack that you just unplug is working fine and continue on to the next.. the one that doesn't make a difference, is the dead one. hope this helps
Old Oct 29, 2007 | 08:44 PM
brasso's Avatar
Its a 1998 5 spd with v2 supercharger. It has no problem starting
Old Oct 29, 2007 | 08:45 PM
brasso's Avatar
thanks man i will do that this weekend
Old Oct 29, 2007 | 08:46 PM
vqmaxman's Avatar
If it were your fuel injectors you can start the car and in park try to rev a bite then see if the misfiring pulses get faster then that's your problem.
Old Oct 29, 2007 | 08:50 PM
brasso's Avatar
thanks i will try that as well
bryants95max
Oct 2, 2015 12:52 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
markevans999
Sep 10, 2015 04:29 PM
