need brighter fog lights!!
Old Nov 4, 2007 | 03:09 PM
maxim82's Avatar
just installed some oem fog in my 95 max and i was expecting to see a huge difference in night time driving. i just thought that they would brighten the road a whole lot better than what it is now. already aimed them to be as high as possible but still dont illuminates a whole lot. so what can be done, new bulbs, would that make a differnce?
Old Nov 4, 2007 | 04:10 PM
MrDicks95SE's Avatar
Offset Is Everything.
they should be aimed lower to the ground, not up. the reason why the mount foglights low is to illuminate the ground when visibility is low duie to rthe reflection off moisture from the headlights. the beam pattern for fogs is wider than the headlights as well but does not focus as foward. if you want brighter lighting, stick with the fog housing but use HID instead of halogen.
even with halogen bulbs in the fogs, you should see a difference in a wider beam.
Old Nov 4, 2007 | 04:25 PM
maxim82's Avatar
i think that the lights that are on there now are some from walmart their about 5 bucks a piece, i was looking into some piaa bulbs like these http://www.piaa.com/Bulbs/Bulbs-H3.html. which one of these three would be the best bet.
1) H3 XTREME WHITE PLUS
2) H3 STAR WHITE
3) H3 SUPER PLASMA GT-X
Old Nov 4, 2007 | 04:38 PM
ive used the 55W Xtreme White Plus before and ive been satisfied up until i switched to HIDs. the others im sure are fairly similar to the Xtreme White bulb. just dont get the 85W one or else you'll melt everything around it.
Old Nov 4, 2007 | 04:45 PM
96max_manSE's Avatar
driving so slow aint easy
put some projectors on that bish
Old Nov 4, 2007 | 04:52 PM
maxim82's Avatar
HOW HARD IS IT TO MAKE THEM HIDS's OR PUT PROJECTORS?
Old Nov 4, 2007 | 05:07 PM
its not that hard its just like retro'ing headlights except their fog lights, as for hid fogs that simple plug and play almost
Old Nov 4, 2007 | 05:08 PM
if you want projector fogs get the is300 fogs sexy.
Old Nov 4, 2007 | 06:38 PM
maxim82's Avatar
I JUST CAME FROM OUTSIDE AND THE LIGHTS ARE NOT BRIGHT AT ALL ITS A YELLOWISH OLD LOOKING COLOR AND THE LIGHTS ONLY ILLUMINATE PROBABLY 8-10 FT IN FRONT OF THE CAR THE BRIGHTEST PART IS FROM THE LIGHTS TO ABOUT 5 FT. BUT ONCE I TURN ON MY HEADLIGHTS ITS LIKE IF I DIDNT HAVE ANY FOGS. IS THAT THE WAY THEYRE SUPPOSED TO BE?
Old Nov 4, 2007 | 07:16 PM
RA030726's Avatar
I'm nutty for Nissans
OMFG. They are fog lights not driving lights.
Old Nov 4, 2007 | 07:32 PM
Hammy
Hit the caps lock. here is pic just incase you forgot where it is.
Old Nov 4, 2007 | 09:15 PM
TurTLe*'s Avatar
from my experience with fogs are it lights up the area under your headlight beam pattern. It fills almost everything in. that is about the most you can expect from FOG Lights because thats what you need to see in FOG.
Old Nov 4, 2007 | 10:24 PM
psu2fan's Avatar
^^ Ditto that, search old posts on this; our fogs are pretty much useless even for fog lights. Also light output is even worse for us 95-96ers, just put cheap bulbs in them or do what others have said and replace them with non-oem fogs.
Old Nov 4, 2007 | 10:47 PM
BlackA32max's Avatar
I hate being slow
why not just go steal the spot light from the cop cars and retro those into your bumper? can't get brighter than that...when they pull you over it illuminates the road around and infront of your car...its BRIGHTER
Old Nov 5, 2007 | 06:54 AM
MaxFanatik's Avatar
my i got piaa xtreme whites. They go out about 10 ft in front of the car and they do go much wider than my headlights. But now i got yellow overlays on the fogs so it cut my light shorter. so between my foglight patter on the ground and my headlight pattern theres a good 6 ft between them...... i need my headlights to be brighter.
Old Nov 5, 2007 | 10:45 AM
+1
Old Nov 5, 2007 | 03:17 PM
dotanj's Avatar
I second the motion about the "spot light"
Fog lights aren't supposed to be that bright (that's why we have headlights and high beams...) They just look cool....
As someone pointed earlier in the thread... they hardly even help during heavy fog...
/dotanj
Old Nov 5, 2007 | 07:22 PM
ejarmol's Avatar
i can't stop laughing
Old Nov 11, 2007 | 09:29 AM
drax89's Avatar
I noticed this too on my 96....i opened them up and took off the glare gaurd....and switched to higher wattage bulbs...output was alot better!
Old Nov 11, 2007 | 12:23 PM
Snypa's Avatar
good luck
Old Nov 11, 2007 | 01:01 PM
Crusher103's Avatar
lol just get HIDs in Ur fogs that should solve Ur problem Ebay FTW
Old Nov 11, 2007 | 02:40 PM
dgeesaman's Avatar
Maintenance Monster
Foglights are one of the least understood features on modern cars. Please bear with me.
1) Foglights are designed to light up the ground between your bumper and the area covered by your low beams. To cover such a wide space that's so close, they are not focused beams like headlights. The purpose is to provide usable light in fog so heavy that your low beams aren't getting through. Considering how short the distance is that we're talking about, this really is about those super-foggy mornings where 25mph is pushing it. I've only driven in fog like that a few times in the 8 years I've owned my Maxima.
2) Aiming the foglights high is a Bad Thing. Since foglights aren't focused beams the light loses intensity within a short distance and so they don't illuminate as far as low or high beams. (What *would* do that is driving lights, not fog lights). There is a problem with what you have now - even though you aren't seeing any better, aiming them up shines very intensely into the eyes of oncoming drivers (and deer too). It's just like high beams. Even aimed properly, foglights shine a lot more at oncoming drivers. Please don't be that asshat.
3) Don't put larger wattage bulbs in. You'll fry the wiring. Many fires have been started under the hood like this.
4) My best recommendation is to polish the glass on the headlamps and fogs, put in fresh headlamps, inspect the wiring for fraying and clean the grounds, and aim them properly. Get them pointed back down where they should be and at least they'll serve their intended purpose and be useful in heavy fog.
There are some people (soccer moms, etc) who leave their stock fogs on 24/7 because they think they see things better. True, there is more road visible, but it's only the road between your front bumper and low beams - the patch of ground where an obstacle would be "too late". If anything, this is more dangerous because the driver tends to look at the most brightly lit part of road, when they *should* be focusing on the farthest reaches of their low beams. Overdriving your lights and not looking far enough ahead is extremely dangerous. So I suggest you only use fogs when it's actually foggy.
Dave
Old Nov 12, 2007 | 01:12 AM
MorpheusZero's Avatar
If you want to see better, do a 9007 conversion or retrofit projectors. As has been said before, fogs are NOT meant to help you in everyday driving situations, and actually they're there primarily to look cool, not to assist you in foggy situations (they really don't unless it's REALLY hairy, even when properly aimed). Ever notice how fog lights are generally an option for more sporty models?
Old Nov 12, 2007 | 02:10 AM
99maximagxe's Avatar
Really good info. I have a gxe that did not come with fogs but was debating if I should get them or not. Contemplating because I have a CAI and it would block off some air going through where the foglight would be mounted.
Old Nov 12, 2007 | 03:23 AM
CAIs take air from the fender, a foglight wouldn't affect that at all. Fogs won't disrupt airflow to an intake unless it's right behind one of the fog "holes."
Old Nov 12, 2007 | 05:38 AM
Prophecy99's Avatar
....fog lights are not another pair of headlights.....
Old Nov 12, 2007 | 09:18 AM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/news.php?readmore=200
problem solved..
Old Nov 12, 2007 | 09:40 AM
Originally Posted by gtr_rider
+1 for 3000k HIDs. i love mine.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
