Fan-assisted air box: another home-made mod.
Old Nov 13, 2007 | 11:24 AM
  #81
kartiste's Avatar
Originally Posted by jvckustumz
well i have 329cfm in my ~=`c~~ which boosts 506hp when it runs at wot for 5 mins and your back tires psi is 12 and your wipers are off, but after all that is done it ends up running at a load of dirt in a fan at 60mph at a great distance with an air filter bringing in 100cfm on the edge which if you add 5% window tint and a set of 26" rims on a 300zx skyline makes the computer go to maxima.org at which point your fan runs on lithium at 70cfm then you purge your wiper fluid and you can beat a fighter jet in a 100 mile race that runs at 10cfm...
now this is what i understand when i read this thread, am i right, is that what happens?????
Yep, you pretty much nailed it.
Old Nov 13, 2007 | 02:59 PM
  #82
dr-rjp's Avatar
Yes...but only if this is your intake...
Didn't one of y'all suggest this?
"Next thing we will hear is someone strapping a Leafblower to the rear of the car because it gives the car thrust."
Old Nov 13, 2007 | 03:04 PM
  #83
dr-rjp's Avatar
Originally Posted by 19Maximus98
Good Luck with that!!
With the cost of replacing your engine when the plastic blades of the bilge pump break off and get sucked into your intake and you have to replace the top half of your engine you might as well have spent all that money on a Supercharger.
Was he serious??!!!
Uh...no.
I can make fun of this stuff too, y'know.
Old Nov 13, 2007 | 03:06 PM
  #84
dr-rjp's Avatar
Originally Posted by Motorhead52
..If you ran this fan, took out the spark plugs and felt for air coming out, there would be next to nothing there.
Yep...next to nothing there.
Old Nov 13, 2007 | 03:07 PM
  #85
dr-rjp's Avatar
Originally Posted by jstew
I had to double check the date to make sure it's not April 1st
That's OK. you still have time to file your taxes.
Old Nov 13, 2007 | 03:08 PM
  #86
dr-rjp's Avatar
Originally Posted by Batxel
I'm not sure if anyone else has said this but do you realize this is a computer case fan? Most cpu fan's can't even handle 6+ years worth of dust before they stop spinning and lock up. This fan will have to deal with a lot more than what your standard computer will have to deal with sitting in a completely controlled environment. There's moisture, dirt, rocks, leaves, and extreme temperatures this fan will have to deal with.
Shh...not so loud. you'll give the fan an inferiority complex.
Old Nov 13, 2007 | 03:14 PM
  #87
dr-rjp's Avatar
Originally Posted by maxima92se
I vote for a flame suite buddy.. This is really funny how did I not see this thread. The reactions are just too funny.
I agree. I mean the comment(s) about "debris, like rocks and pebbles getting into the intake"...now that is hysterical.
After six years of use, and putting on 100k in my I30, I found a total of 20 grains of sand sitting on the bottom of the stock box, and about 2 grams worth of dried-out, tiny bug parts inside my air filter when I opened it up.
Air has enough trouble making it through that narrow slot lying between the top of the radiator and the front of the hood.
Nah....not as funny as drilling holes in the bottom of a stock airbox. Nothing says "sucky performance" like a "hot air intake" or HAI for you acronuts.
Old Nov 13, 2007 | 03:16 PM
  #88
dr-rjp's Avatar
No wait, I forgot about those other hacks that run a hose from under their car to that elbow joint in their snorkle...
Why, yes, it does create air flow....right out the FRONT OF THE INTAKE!!!
Old Nov 13, 2007 | 03:33 PM
  #89
MorpheusZero's Avatar
Huge font = huge ***** and you are right while everyone else is wrong.
Old Nov 13, 2007 | 03:36 PM
  #90
tvis's Avatar
lolz... and somebody doesn't know how to multi quote in one post.
Old Nov 13, 2007 | 03:39 PM
  #91
dr-rjp's Avatar
Originally Posted by h22enjen
Oh know, what did you do!! I think the fan would only be a restriction buddy. In theory it adds more cfm and the specification numbers rock!! but in reality, its nothing. Try getting a 3in pipe thats 1.5-2 feet long, and put the fan on the other end, if you felt anything, its little to none.... now imagine that same pipe with ridges all around and mutiple bends on the pipe, its not happening. Atleast you tried, but this idea has been around as long as civics has been around. And all that improvement, I think its a placebo.. but everyone feels different so... nice try though! but if you are dynoing, definately interested to see what the changes are! (good or bad)
As a matter of fact, when I was testing this with my spare stock intake, I installed the fan in the opposite direction (by mistake). When I hooked it up to my battery, the air coming out of the scoop blew over a bag of empty, 1 liter soda bottles (that were going out for recycling) and sent the soda bottles rolling out my flat driveway.
I plan on running some pressure tests on it, just to see what amount of pressure drops I'm getting across the fan.
Old Nov 13, 2007 | 03:41 PM
  #92
dr-rjp's Avatar
Originally Posted by maxx0831
nice i like it
Thank you. I appreciate the support (as limited as it might be).
Listen, if you have a stock air box, i'll be happy to send you a fan for free to try.
Seriously.
Old Nov 13, 2007 | 03:43 PM
  #93
dr-rjp's Avatar
Originally Posted by Tatanko
You have got to be sh*tting me...
SHIFT_happens
Old Nov 13, 2007 | 03:46 PM
  #94
dr-rjp's Avatar
Nope. The large font is help someone like me who obviously cannot see the BIG picture.
  #95
bigpulve+'s Avatar
WHY ARE WE YELLING SO LOUD??????
Old Nov 13, 2007 | 03:47 PM
  #96
d00df00d's Avatar
Old enuf to pick his own gears
Kids, whether this is true or not, it's mind-numbingly simple.
At low speeds, when you're just bumbling along and demanding less than 107 CFM, the fan is pressurizing the intake tract slightly. So, when you open the throttle, you don't have to wait for that entire column of air to start moving before you get power.
Once you start digging into the throttle and getting the revs up, your engine quickly starts demanding more than 107 CFM. At that point, the fan does nothing but generate turbulence and restrict airflow.
In other words, it makes the car faster when you want to drive it slow, and slower when you want to drive it fast.
See? Simple. Quit whining.
Old Nov 13, 2007 | 03:48 PM
  #97
dr-rjp's Avatar
Oh...I know how, but I like the personal touch of individual replies much much better.
Old Nov 13, 2007 | 03:51 PM
  #98
d00df00d's Avatar
P.S. Delta makes great fans. Unless the lower intake tract disintegrates or sucks in rocks, those blades are NOT going to break.
  #99
dr-rjp's Avatar
Originally Posted by d00df00d
Kids, whether this is simple or not, it's mind-numbingly simple....the fan does nothing but generate turbulence...
Again with the turbulence...
...like the sharply angled stock air box and the MAF screens let the airflow through without any.
The worst thing that could happen is not my fan making things worse.
No. The worst thing is that the fan actually helps.
I'm out..
Old Nov 13, 2007 | 03:58 PM
  #100
I'm out..
You're right. That would be horrible.
Old Nov 13, 2007 | 04:03 PM
  #101
d00df00d's Avatar
Do you have any idea what a fan does to an air stream that is trying to move at over twice the fan's output?
What do you expect that giant impeller to do to your flow rates when it almost completely covers the opening in the intake tract?
I'm being generous here. If you seriously think that tiny MAF screen (it can actually straighten air flow) and the angles in the stock air box (which holds a large volume of air and has a giant air filter in the middle to spread things out) are major points of restriction and sources of turbulence, you probably aren't equipped to continue this discussion, much less answer those questions. I'd just like to give you the benefit of the doubt...
Old Nov 13, 2007 | 04:46 PM
  #102
TunerMaxima3000's Avatar
I'm out..
basically, the best thing you can expect from this fan is for it to create a swirling effect which will in turn aid in air / fuel mixing, and help fuel mileage/performance. that is why some people think those 'tornado' inserts are a great idea.
But the gain's aren't worth the losses you'll see from the restriction.
That is the sum up, make your own decision.
If you idle all day, this is a great idea,
if you move your car, its a waste of time and energy.
OH> STOP YELLING!!!
Old Nov 13, 2007 | 05:27 PM
  #103
nismology's Avatar
This is assuming there's a vacuum in the intake tract at low throttle angles. I don't really think this is the case. From what I know the giant earth supercharger @ 14.7 PSI does quite well for itself.
Old Nov 13, 2007 | 06:03 PM
  #104
The earth doesn't run off your crank, therefore it is effectively a turbocharger.
Old Nov 13, 2007 | 06:08 PM
  #105
d00df00d's Avatar
It's a NA engine. There's always a vacuum.
Old Nov 13, 2007 | 06:11 PM
  #106
nismology's Avatar
Vacuum aft of the throttle plate, yes. Vacuum in the intake tract, don't think so.
  #107
nismology's Avatar
*grumble*
Old Nov 13, 2007 | 06:20 PM
  #108
agreed.
LMAO
Old Nov 13, 2007 | 06:23 PM
  #109
NmexMAX's Avatar
dot dot dot ...
11.34 PSI here, I have a boost leak at this altitude.
Old Nov 13, 2007 | 06:26 PM
  #110
^how high are you? lol
Old Nov 13, 2007 | 06:30 PM
  #111
Old Nov 13, 2007 | 06:52 PM
  #112
d00df00d's Avatar
....How is that possible? The two are never sealed from one another. There may be less vacuum upstream of the TB, but there's still vacuum.
And either way, if the fan is generating enough pressure to move 107 CFM, and if the engine isn't generating enough vacuum to draw 107 CFM, doesn't that mean by definition that the fan will be adding pressure?
Old Nov 13, 2007 | 07:18 PM
  #113
nismology's Avatar
Atmospheric pressure prevents a vucuum from occuring ahead of the TB. You don't give it enough credit.
The engine is generating enough vacuum to draw 107 CFM but the throttle plate won't let it. A matter of semantics but just wanted to clear that up.
Atmoshperic pressure >>>>>> a fraction of a PSI that this fan could generate (which is probably completely negated by the filter itself) at idle just like drivetrain inertia >>>>> an UDP. The engine swallows all the air it can based on how much the throttle plate allows it to. Like I said, I don't think you give atmospheric pressure enough credit.
Old Nov 13, 2007 | 07:24 PM
  #114
Stop saying vacuum. I feel like we're in the Hoover appreciation thread at www.maidsofamerica.org.
Old Nov 13, 2007 | 07:25 PM
  #115
EnervinE's Avatar
i has college
Well, I'm late for this party.
Old Nov 13, 2007 | 07:31 PM
  #116
How sweet duh sound.
Old Nov 13, 2007 | 08:32 PM
  #117
19Maximus98's Avatar
Wait, what happened to the guy screaming about his leafblower turbocharger? I want to see some more of those sweet pics.
Old Nov 13, 2007 | 09:46 PM
  #118
d00df00d's Avatar
Okay, so you're not actually saying there's no vacuum ahead of the TB or that the fan makes no pressure, just that those effects are minimal? If that's the case, I agree.
EDIT: And I guess I should have referred to the intake tract rather than "the engine" in my original post...
Old Nov 13, 2007 | 09:50 PM
  #119
Another thing: This might actually raise the idle a bit. I'm not sure how much of a buffer the IAC is.. probably enough to soak up the extra pressure, but it would be interesting to see.
Old Nov 13, 2007 | 09:58 PM
  #120
nismology's Avatar
I am saying there's no vaccum in the intake tract at low throttle angles. When you breathe in, the vacuum created in your lungs causes air to rush in. That does not mean there is vacuum present in the mouth/nasal passages. In these cases, moving air is just nature's response to the vacuum, not vacuum itself. If you read about PCV systems, air from the intake tract actually enters the crankcase via the breather tube to dilute the blow-by gases and oil vapors at idle and moderate throttle angles. This is the principle upon which modern PCV systems are based. Air isn't sucked out of the crankcase at the breather until very aggressive throttle angles are introduced.
I'm also saying that the fan generates very little pressure, if any. My opinion is that the pressure drop through the filter would invalidate any pressure it could put out and unless the air box is completely sealed ANY excess pressure would leak out of the holes anyway.
