Engine Clearance
Old Nov 6, 2007 | 08:48 AM
mevjen's Avatar
The self-oil changing max
Engine Clearance
I am taking out my engine and I need some advice on how high to take the car up, best method (and cheapest) etc. I was thinking some rhino ramps from walmart?
Old Nov 6, 2007 | 09:15 AM
urmab's Avatar
you don't need to raise your care up if your taking the engine off. I would just put it on jack stands. since you probably going to disconnect the axles to disconnect the tranny from the engine and them pull it out.
Old Nov 6, 2007 | 09:30 AM
mevjen's Avatar
I am dropping it, not raising it.
Old Nov 6, 2007 | 09:40 AM
pmohr's Avatar
No more Maximas...
Throw a measuring tape down from roughly as high as the top of the UIM down to the bottom of the oil pan. Raise it that much + 6 inches or so.
Unless you have a trans jack or something that can take the weight, I wouldn't just park it up on ramps. You'll probably need to drop the motor down, then raise the car up.
lowpost99
Oct 26, 2025 06:53 PM
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
