problem with starting? help plz!!
Old Nov 15, 2007 | 05:32 PM
MaximaPower's Avatar
today my car started up funny...when i turned the key u can hear it trying to turn over but it wouldn't start...i had to press the gas pedal a lil bit then it finally started after about 3 tries...now, it wont start at all...wont even crank......but there's a "wooooooo" sound that lasts for about 2-3 seconds whenever i turn the key to the "on" position (not cranking the engine)....i'm almost 100% sure it's not the starter because I know wat a bad starter sounds like cus i had to replace it about 40k miles ago.
my car currently has 137k miles and i just replaced the fuel filter about 3 wks ago...and has a fairly new battery (only about 7-8months old)
wat can this be? any help is appreciated...thanks!!
Old Nov 15, 2007 | 07:11 PM
EnervinE's Avatar
i has college
Is the "woooo" sound the fuel pump...?
Old Nov 15, 2007 | 07:52 PM
19Maximus98's Avatar
Like Enervin said, check the Fuel Pump. Pull the rear seat out and remove the fuel filter cover(3 bolts I believe) disconnect the fuel pumps electrical plug and check the resistance at the fuel pump. Search the forum for "Bad Fuel Pump" or "Fuel Pump Resistance" you should find more details about FP's. Good luck
Old Nov 15, 2007 | 10:10 PM
thanks!! that's wat i was thinking as well...i'll take a look at that....sux i was stranded at work earlier tonite cus of that =(
Old Nov 16, 2007 | 03:35 AM
showdown's Avatar
Because I Can
i had the SAME exact problem...it turns out i needed a new knock sensor...and since i tried to start it up so much that it went to the "woooo" stage and i ended up needing a new starter
Old Nov 16, 2007 | 03:36 AM
showdown's Avatar
Because I Can
see if this helps...maybe...
http://groups.google.com/group/alt.a...a40e868520ff2c
Old Nov 16, 2007 | 09:21 AM
thanks! i'll look into that too
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
