Homelink/garage door opner
I can not get my garage door opener to program my buttons in my car...i have done the directions...i was able to get my gate opner to work with it..but not my garage...any sugestions???
Yea, I have old one and it won't work, works on my girls house though......can't remember all the details was very specific instructs, but you got it with the gate thing,.......check dip switch settings on garage door, set to different freq. within Homelink's range?? good luck.
Are you pressing the "learn" button on your door opener?? Most common issue, make sure you follow the directions from your door opener (2yr old opener should work, but rolling code requires extra step)
Pull the car directly under the opener. There is a small button on the opener called "learn". Press it and then run the Homelink learn sequence. I got mine to work that way. Following the directions from Homelink didn't include setting the opener to learn mode.
Dave
Dave
Ahhh I had the same problem with my '97 maxima and my garage door opener. We just built a new garage this past summer. I ended up contacting homelink and they told me that the 2 were not compatible. The homelink on my '97 uses one code and the new style garage door openers use a "rolling code". They only way around this is to purchase some sort of universal code changer. You attach it to the garage door motor and it will receive the code transmitted from your car. It will then change the code to "trick" the motor into believing that the proper code has been sent. Presto, your garage door is opening. About 50 bux at home depot.
hope that helps.
here's their contact info.
hope that helps.
As degeesaman said, I had the best luck programing in my garage. The Homelink unit is just a universal remote control, so once it is locked into the remotes freq you have to get the door opener to sync with it. The old dip switch door openers are super easy once the homelink and the remote sync your set. The newer "rolling code" units need the extra step. If you have the instructions for your opener, program the remote to the homelink and then treat the home link as a "new remote" and program it to the opener. If you don't have the instructions you may have to try a few times to make it work. The last one I setup was easy, program the home link and then press the "learn" button on the opener until the light came on, then press the programed button on the home link. Light flashed and the door opened.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
