~viberation~ please help
Old Nov 19, 2007 | 06:18 AM
jvckustumz's Avatar
ok my car is vibrating when i hit around 60 and above, however it only does it when i press the gas, if i let off the gas it rides perfectly, what could cause this??? thank you guys!!!
Old Nov 19, 2007 | 08:57 AM
heynow's Avatar
axles perhaps?
Old Nov 19, 2007 | 09:20 AM
Snypa's Avatar
axle...maybe alignment......busted boots.
Old Nov 19, 2007 | 09:31 AM
merlin2375's Avatar
motor mounts if it's only happening when you're foot is on the gas?
Old Nov 19, 2007 | 09:37 AM
ROCKART's Avatar
wants an I35
almost 1000 posts DOOOD
yea mounts is a good call but unlikely - the vibration would be at idle as well, if not stronger then.
it sounds like it could be some kind of intake or fuel issue (maybe fuel filter?). if it was axles you would feel it all the time, not just when gassing.
Old Nov 19, 2007 | 10:07 AM
rockfordmaxII's Avatar
i dont mean to hijack the thread, but when im cruising at a constant 70 or so (highway speeds) there is a constant vibration thats going through the floor and its kind of annoying. the steering wheel is fine, no vibration at all, i just had a rotation and balance. so maybe some kind of bushings are worn? the car is also lowered on tokico blues, so could the stiffer suspension be causeing a slight vibration?
Old Nov 19, 2007 | 01:37 PM
jvckustumz's Avatar
well see it is my steering wheel that vibrates along with alittle vib. of the whole car and at low speeds even if i hit 5000 rpm it doesn't do it, just when i hit the gas around 60 to 90, faster than 100 doesn't vibrate...
Old Nov 19, 2007 | 09:24 PM
OnEBadAsSi30's Avatar
Possible wheel bearings. I know under light/heavy acceleration it would make my steering wheel shake.
Old Nov 20, 2007 | 05:51 AM
Snypa's Avatar
i was thinking motor mounts when he said it too.......but i guess your kinda right about vibrating at idle as well.
Old Nov 20, 2007 | 06:35 AM
jvckustumz's Avatar
glad its not my axels (maybe) wheel bearings.. hmmm how expensive are those little bas tards??
Old Nov 20, 2007 | 06:39 AM
hectorc's Avatar
Upper Midwest Wheel Whore
Wheel beraings are not too bad. Probably about $40 tops..the thing is that it's a pain to press in the bearing when replacing.
Old Nov 20, 2007 | 06:54 AM
ROCKART's Avatar
wants an I35
if it was wheel bearings why would it only be happening when he is above 60mph?
Old Nov 20, 2007 | 06:55 AM
heynow's Avatar
good question
Old Nov 20, 2007 | 06:58 AM
jvckustumz's Avatar
maybe it was just my imagination... or the road,
what about my tranny?????
could something be f'ed inside there?
Old Nov 20, 2007 | 07:02 AM
ROCKART's Avatar
wants an I35
im guessing no.
im still thinking intake or fuel systems. you running codes at all?
Old Nov 20, 2007 | 07:07 AM
jvckustumz's Avatar
iat code lol, my fuel pump is about to be shot tho i think, at idle sometimes my car dies
Old Nov 20, 2007 | 07:10 AM
ROCKART's Avatar
wants an I35
your car dying at idle and this issue of 60+mph vibration i bet is the same problem. MAF...fuel systems.
Old Nov 20, 2007 | 07:18 AM
jvckustumz's Avatar
could be.... it hasn't done it since i started this thread tho, i drove like 95 miles yesterday and it didn't do it but it was just on the way back from ponca city that day on the turnpike, didn't do it when i started getting close to home
Old Nov 20, 2007 | 07:54 AM
hermtm2's Avatar
I have a similar problem. The vibration is starting aroud 60 mph and then it goes to peak at 75 mph. The streering wheel isn't vibrated but I feel like the whole car is vibrated like seats and acceleration pedal. I've been on repair shops several times to align the wheels but they counldn't fix the problem. The tires are fine.
Old Nov 20, 2007 | 08:31 AM
Snypa's Avatar
i dont think its the intake or fuel systems......its kinda hard to dignose though.....and there are no cels?
Old Nov 20, 2007 | 09:52 AM
yeah pretty much the same here.
Old Nov 20, 2007 | 09:57 AM
wetzelman1's Avatar
if it's only happening at certain speeds, you probably need to get your wheels balanced. also check tire pressure. if it was anything besides this, you would have vibration all of the time.
Old Nov 20, 2007 | 01:08 PM
jvckustumz's Avatar
tires are balanced and brand new(got them 1hr b4 the trip) and i ran my car at 35 psi all around, lug nuts were also torqued down...
2_da_max101
Oct 26, 2012 09:17 AM
MaxedOut99SE
Apr 18, 2007 03:00 PM
maxs4life
23
Jul 23, 2006 06:40 PM
maxs4life
Jul 10, 2006 06:14 AM
MrGone
Sep 27, 2003 06:18 PM
