help with heater
Old Nov 19, 2007 | 05:36 PM
aznsap's Avatar
help with heater
so i have a 95 gle w/ the auto climate control. my heat isn't work, do you guys know why?
when i press the econ button, air comes out but it's not warm at all.
any ideas?
Old Nov 19, 2007 | 06:47 PM
Nopike's Avatar
I think a thermostat that is stuck can cause that problem.
Old Nov 19, 2007 | 06:51 PM
Nopike's Avatar
What is your temp guage reading? If it is stuck on cold you most likely need a thermostat.
Old Nov 19, 2007 | 09:22 PM
KRRZ350's Avatar
Using my spidey sense i've determined that your heater core is plugged, but it could also be that your flapper valve's aren't opening, water **** is fuxord, thermostat is stuck, coolant level is low, and possibly some more that I can't think of right now.
Old Nov 19, 2007 | 10:20 PM
aznsap's Avatar
okay so say my temp gauge is working correctly (i'm assuming you guys mean the coolant temp gauge).
don't think the coolant would be low seeing as i don't have any leaks anywhere.
so what/where are the heater core, flapper valves, and water ****? and how do i check those?
Old Nov 20, 2007 | 05:58 AM
Snypa's Avatar
new thermostat MAY fix the problem.
Old Nov 20, 2007 | 06:28 AM
aznsap's Avatar
if the thermostat is broke, wouldn't the engine temp gauge not be working correctly?
Old Nov 20, 2007 | 07:01 AM
heynow's Avatar
try using auto set to 75+ to see if you're getting any warm air @ all (when the coolant temp gauge is at 1/4 at least)
Old Nov 20, 2007 | 07:02 AM
heynow's Avatar
not neccessarily, my t-stat was stuck open, and it took a long-*** time to warm up.
Old Nov 20, 2007 | 07:06 AM
jvckustumz's Avatar
he is 100% right, mine did that as well...
Old Nov 20, 2007 | 07:09 AM
altimax06's Avatar
If the thermostat is stuck open, then he would eventually get heat out of his vents. I would make sure the control actuator is opening the valve for your haetercore. Hater core can also be plugged. I would look in that area first.
Old Nov 20, 2007 | 07:11 AM
jvckustumz's Avatar
but if the heater core is plugged wouldn't that restrict coolant going through and cause the car to overheat abit??? heater cores are a ***** to replace also, so it sucks if that is the prob.
Old Nov 20, 2007 | 07:12 AM
aznsap's Avatar
ya, i spent 3 hrs driving yesterday w/ the heater on the whole way and i was only getting room temperature air coming in.
is it hard to check the valve in the heater core? i'm fairly competent but have never had to work w/ the heater system before, so its' new to me.
Old Nov 20, 2007 | 10:31 AM
heynow's Avatar
just to make sure, set it to auto, and crank it up to the max! I know that using ECON will only yield lukewarm air.
Old Nov 20, 2007 | 02:01 PM
aznsap's Avatar
okay new symptom guys. my heater worked today.
so i guess the problem is intermittent.
howardis
Dec 11, 2019 06:10 PM
dr3am
25
Oct 22, 2015 08:53 PM
RWCreative
Sep 21, 2015 11:01 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
