Taking off Dashboard problems
Old Nov 21, 2007 | 06:11 PM
MaximaPimpin's Avatar
I am trying to take off the dashboard in order to get to the guages and change my lights. I ran to a problem and can not pull the dash off no matter what I do, I have been following the guide but are there any screws under the steering wheel and dash that im missing or something? It feels like something is holding it down. Thanks for the help guys.
Old Nov 21, 2007 | 06:37 PM
BLACKonBLACK98's Avatar
Former Vendor
you are taking out the dash board to change the cluster? anyways... way up towards the windshiled there are 2 screws in the vent looking things. did you get those?
*edit* btw all you have to do to get the cluster out is drop the steering wheel and remove the trim. taking out the dashboard is WAY overkill unless i'm misunderstanding.
Old Nov 21, 2007 | 06:44 PM
maximabebe's Avatar
Did you already get the 4 reverse Torx screws out?
Old Nov 21, 2007 | 07:08 PM
KRRZ350's Avatar
Your CRAZY if that's the case. In fact, if I'm not mistaken removing the gauge cluster is a step in removing the dashboard!
Old Nov 21, 2007 | 07:22 PM
Former Vendor
lol... so true.
Old Nov 21, 2007 | 07:25 PM
67whitegoat's Avatar
The cluster should come out in 10 min. or less.
Old Nov 21, 2007 | 07:34 PM
Two scews in top under side of gauge bezel. Now the bezel "just pops out". It is held in by spring clips and is tough to remove. (Once the two screws are removed the clips are the only thing holding the bezel in.) Once you finally get that SOB off, only four screws holding the cluster in. Remove the screws and unplug it.
Old Nov 21, 2007 | 09:27 PM
That's exactly the step which i am on. We can not get it out and we have removed all of the screws. We managed to get a couple clips to pop out but no matter how hard we pulled on the rest of it, it would not budge. We were thinking of any type of screw that could be holding it and managed to find none. Is there a method to ripping it out, because 2 people couldn't budge it and im positive i removed all the screws because i followed the guide from the interior thread.
Old Nov 21, 2007 | 10:53 PM
cefiro8701's Avatar
go to my cardomain...i have step by step instructions on taking off the gauge cluster
Old Nov 21, 2007 | 11:22 PM
maxpeed96plat.'s Avatar
Lower your steering wheel to it's lowest setting.
Old Nov 21, 2007 | 11:57 PM
KRRZ350's Avatar
I've found it's still to risky, I've done it both ways, just drop the column
Old Nov 22, 2007 | 05:53 AM
vq35maxima4lifee
i'll make a video on how to take it out and post tonite edit: tomorrow night
Old Nov 22, 2007 | 07:53 PM
There is no trick to it. It's just clipped in tight.
Old Nov 23, 2007 | 12:07 PM
vilmaxima's Avatar
drop the steering wheel now look under the steering wheel theres i think 6 screws remove those(they are pretty far in the hole), pop the top plastic part of steering column off, 2 screws holdin in the cluster shroud at the top, should pop out(try bottom first, might have to bend the top a bit to fully pull it out) then 2 screws on top 2 on bottom and u got your gauge cluster out.
Old Nov 23, 2007 | 08:58 PM
Heh so many different methods. I will try again tomorrow morning because i had no time lately. Thanks for all the responses and different methods, i will try each one until i can finally get that SOB out.
Old Nov 25, 2007 | 11:19 AM
lilaclucymaxima's Avatar
Team Ramrod
You don't need to touch the steering wheel to get the gauge cluster out. Just look around next time. http://www.geocities.com/amixam69/ni...ash/index.html
Old Nov 25, 2007 | 08:22 PM
Yeah...that was the guide i was following and the black area around the guage cluster won't pop out. I did look around . I got side tracked into dynomatting all of my doors heh but as soon as i am done with that project i will try to pop that **** out again.
Old Nov 25, 2007 | 09:53 PM
CRiME's Avatar
oem ftw!
it does pop out, but in the process, i broke mine in the lower right corner
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
Maxima30
Sep 7, 2015 06:13 PM
nbstriker10
Sep 4, 2015 04:26 PM
