Brake squeal when reversing
Old Nov 23, 2007 | 06:03 AM
holymoly's Avatar
After watching my nephew change his own brakes, I decided to do the same for mine and was very proud of.
One thing is that everytime I back up slowing with brakes applied the squeal can be worse than a step on cat's tail whine.
I didn't have this before and yes I did use anti-squeal on pads.
Old Nov 23, 2007 | 06:23 AM
Maxgig's Avatar
You fix that by "combat parking." lol, just kidding.
I had that problem on my 4th Gen on 2 separate occasions. The first time I forgot to clean the crap off my new rotors, the second time I was lazy and just sprayed some brake squeal eliminator on them and did a few hard stops. Both times I had used the brake gel as well. Hope this helps you cause I know you don't want to go in there again. Good luck.
Old Nov 23, 2007 | 09:57 AM
dgeesaman's Avatar
Maintenance Monster
Did you use your stock pad shims?
Shims >> anti squeal goo
Old Nov 23, 2007 | 10:56 AM
Nopike's Avatar
If the pads have mosture on them it will do that. Once the pads get broken in a little this should go away. I have had the same problem when installing new pads, it should go away after a few days of driving.
Old Nov 23, 2007 | 10:57 AM
kzoosho's Avatar
Brakes make noise new old good or bad . Try washing the car also as brake dust will cause niose too.
Old Nov 23, 2007 | 11:33 AM
Nopike's Avatar
holymoly, I know what you are talking about they sound really bad when you back up for the first few days, it goes away quickly. The pad has to "seat" itself to the rotor that happens after driving for a few days.
Old Nov 23, 2007 | 11:41 AM
holymoly's Avatar
I did use the shims, cleaned em and put them back.
Problem is I changed my brakes in early August, still waiting for it to go away.
should I wait a few more days....
Nopike's Avatar
I just noticed, did you install the shims from the old pads or install new shims? If noise continues to a degree where it still bothers make sure you install shims. I know some pads have shims already attached but if you keep having noise issues you need to add shims, most auto parts stores carry them. The shims are specific to the Maxima pads, they are not universal, I only had to add shims to my front pads the back ones were OK. The shims are more of an issue for normal braking noise and not the backing up issue.
Old Nov 23, 2007 | 04:00 PM
Concord's Avatar
Totally Chronic problem on the 4th Gen. Nissan makes a revised pad retainer for "moaning" when backing up in reverse.See service bulletins. I have them installed on my car with all OE shims and the damn rear brakes still moan from time to time. Anything but original brake pads will moan moan moan.
Old Nov 23, 2007 | 04:11 PM
Nopike's Avatar
Yea wait a few more days, lol. Mine only make that moaning noise in reverse if there is moisture on the pads such as very humid day or right after a car wash, goes away quickly.
Old Nov 23, 2007 | 04:19 PM
MDeezy's Avatar
check the bolts on the torque member.
I had this problem in my beater car, and I saw I had a loose bolt in the caliper braket (which I still think the shop that aligned the car set me up)
Old Nov 23, 2007 | 04:59 PM
holymoly's Avatar
Thanks for your input Concord, but these are my third replacement with Wagner organic pads, definitely not OE,
The bolt on the caliper, maybe...
Old Nov 24, 2007 | 09:22 AM
Concord's Avatar
I was referring to a moaning/squealing pad noise, not a noise caused by improper installation . If everything is installed correctly then what I described is what you got.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
