help my hand brake light on!!
Old Nov 23, 2007 | 08:16 AM
indeep's Avatar
hey guys I dont know what happen this morning my hand break light just came ..and now i have like 4 lights on my gauges... service engine light,hand break light, hightbeam light and air bag light..i dont know what too do now...is there a way I can reset all of these lights by unplugging the batteries? let me know or i gotta take it down to the shop today..
thanks.
Old Nov 23, 2007 | 08:31 AM
jvckustumz's Avatar
check your brake fluid, if it is out or low then your light will come on
Old Nov 23, 2007 | 08:51 AM
merlin2375's Avatar
If it was just the brake light, I would say check the brake fluid level to make sure it's topped off. You can also check that the parking brake is going all the way down.
If all of your dash lights are coming on, could be an alternator/charging issue. Sometimes when the alt. is dying it causes all kind of weird lights to show up on the dash
Old Nov 23, 2007 | 08:56 AM
indeep's Avatar
alrite thanks guys I hope its not my alternator..since i bought this car i had replaced my alternator atleast 4x in 1 year..but i will take a look at it and let you guys know whats the deal..
Old Nov 23, 2007 | 09:13 AM
jvckustumz's Avatar
mine always came on b.c the alt. belt broke but i would take it to oreillys, they do a alt, starter and batt check for free
Old Nov 23, 2007 | 09:18 AM
xkazik's Avatar
when my alt when bad the battery and break light went on ..
Old Nov 23, 2007 | 09:45 AM
indeep's Avatar
lol if it is my alt..then i know it only happens in winter when it snows etc..and in canada where i live on toronto..just snowed yesterday and then i start getting alt problems i dont know why...
Old Nov 23, 2007 | 10:27 AM
kzoosho's Avatar
Well i would check the fluid first before you go out buying something you may not need.
Old Nov 23, 2007 | 10:34 AM
indeep's Avatar
yea i will do that..thanks..
Old Nov 23, 2007 | 06:22 PM
andrei3333's Avatar
Maybe you have a problem that you have not found yet and your alternator keeps dying due to that un-found problem >?
BTW have you visited TMEC yet ?
Old Nov 23, 2007 | 06:52 PM
Reece616's Avatar
i had that problem too...
i checked added brake fluid and solved that problem real quick.
as for the alty problem, i would say u have to check the wiring. my friend's dad used to change alternators more than his clothes (well not that bad but u get the idea haha) and it was because of a short circuit. check it out, hope it helps.
Old Nov 23, 2007 | 09:20 PM
Snypa's Avatar
get it checked out son
Old Nov 23, 2007 | 09:31 PM
99SEmatic's Avatar
I would suggest that you take a look at your brake pads as well. I've noticed my brake fluid level gets a little low when it's time to change the pads.
Old Nov 24, 2007 | 06:06 AM
Atimaxx's Avatar
Sounds like an alternator issue. Have a place like Autozone check your alt and battery with their testing equipment and see if they can give you a solid answer. It could be as simple as your serpentine belt needs tightening (if it was loose, it would cause poor charging). If you have had to replace the alternator four times in one year, that indicates a major problem and means you have other electrical issues going on in your car. And those other issues are killing your alternator.
Also, it would be good to check the main wiring and grounds going to the alternator from the battery. Make sure they both have a solid, CLEAN, connection.
Old Nov 24, 2007 | 07:58 PM
honor_your_life's Avatar
I just had the same problem (Airbag light, Check Service Engine light, battery and The one with the exclamation mark lights). Now I know my entire exhaust system has to be replaced (Check Serive Engine Light came on, and I brought it to a shop to get it checked out). But about 2 weeks ago when I was driving up north to go back to work, the light with the exclamation mark turned on and the battery light. I just pulled into my drive way and kept it parked until last night.
Last night I started my car (-25c outside), I let it there and let it warm up. I just had to move it a few feet to park in front of my snowmobile. I moved it a bit, and then my max killed itself. I then tried to start it again, no luck. It didn't even turn.
So I tried again tonight, nothing happened. I mean no lights, the key remote didn't work, nothing. I talked with a few light-duty and heavy-duty mechanics that I work with and all them said its probably the altenator or a belt.
By the way, the battery is 1 year old and the car always starts in these temperatures.
What could be the problem?
Sorry to jack the thread, but no point starting another thread about the same thing.
Thanks alot,
-Ryan,
Old Nov 24, 2007 | 09:37 PM
andrei3333's Avatar
! + batt light coming on steady is either the alternator belt (or lack there of since it could have snapped) or the alternator itself, or a random problem that i was having when these lights would come on and ff randomly....
Now for you since everything died, first look to make sure you still have a belt on, if you do then your alternator died 99%
Old Nov 24, 2007 | 09:48 PM
andrei3333's Avatar
^ thats nice to know man, really
Old Nov 25, 2007 | 04:27 AM
:P
Thanks alot, I am going to check right now.
Old Jan 18, 2014 | 06:44 PM
ssneakster's Avatar
what was the random issue causing the exclamation and battery icon caused by? my wife's 2001 maxima is doing that.
Old Jan 18, 2014 | 11:14 PM
max ride 41's Avatar
ummm, you might want to look at date of thread. i think it was fixed back in "07
Old Jan 18, 2014 | 11:39 PM
Fakie J Farkerton's Avatar
He's
Just tell him alternator and
Old Jan 22, 2014 | 07:08 AM
Patm-a32's Avatar
thanks.
Mine was on forever at one point... Was just low fluid check that first
Old Jan 22, 2014 | 07:12 AM
6cyl-97maxima's Avatar
Mine came on after having the the entire, (except for the booster), brake system replaced. It went back out after a bit of driving.
Old Jan 24, 2014 | 12:19 PM
CMax03's Avatar
Make sure the Brake reservior is topped off and that the float inside the brake reservior isn't stuck in the bottom of the reservior. You can use a small pen on screwdriver to dislodge it from the bottom of the reservior! Make sure the parking brake is down when you check this!
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
