Smell gas in 95 Maxima
Old Nov 23, 2007 | 10:17 PM
asamu-95max's Avatar
My car has been smelling gas when I start it. One week ago when I started it, it revved to 2000 rpm and I think that's when it started smelling gas when I start it. Noew it's smelling gas when I start it and through the air vents... I have changed the fuel regulator and the other problem could be the injectors. Does anyone have an idea what other problem could cause this..........
Old Nov 23, 2007 | 10:50 PM
maxpeed96plat.'s Avatar
What codes are you getting?
Old Nov 24, 2007 | 12:18 AM
Singer's Avatar
I have this problem as well, I was told it could be the evap canister.
Old Nov 24, 2007 | 12:31 AM
vqmaxman's Avatar
It, can be alot of things like fuel injectors, fuel rails leaking, evap cannister and Fuel filter. I would pull out the codes first and check back with the answer. I think its' the fuel filter it's not filter and that's allowing the fuel to come in to your vents.
Old Nov 24, 2007 | 01:00 AM
P0100 and P1335. This stated b4 the CEL came ON......
Old Nov 24, 2007 | 08:37 AM
sparky1562's Avatar
P0100 is MAF
P1335 is crank pos sensor (REF).
I just started smelling fuel as well on start up. Part of mine is leaking exhaust I think, at the muffler, getting back into the cabin. I also plan to clean the MAF.
Old Nov 24, 2007 | 08:39 AM
sparky1562's Avatar
What is the problem with the canister, if this is it?
Old Nov 24, 2007 | 08:55 AM
MDeezy's Avatar
does it smell like burn gas? like from the exhaust?
or like gas falling on hot parts and burning?
if you smell gas, pop the hood, look and sniff. if needed do it while the car is still running
PH98I30
19
Jun 13, 2016 02:38 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
Jcof88
Aug 3, 2015 10:43 PM
