Hard pulling after 2000RPM
Old Nov 28, 2007 | 01:52 PM
eskim_77's Avatar
Hi guys,
I recently noticed that my car wasn't pulling smoothly after 2000RPM. If I depress gas hard enough, RPM will go up but I don't feel like my car is responding to its engine as it used to be. Not sure if it is grinding sound but I do hear something loud after 2000RPM. During this, if I switched my gear(auto) to N(eutral), I don't hear or see this hardness at all. Engine rev very smoothly like old days.
Recently, I replaced a starter but I have no doubt that is a cause of problem.
I hope it's not a transmission related but would seek any opinion.
Thanks in advance.
Old Nov 28, 2007 | 02:21 PM
mowgli29's Avatar
Horizontally opposed.
It sounds to me like your torque converter might be slipping. That would explain the RPM's going up, but the car not accelerating quickly.
Old Nov 28, 2007 | 02:32 PM
pmohr's Avatar
No more Maximas...
Does this happen in all gears, only a specific gear? When cold, warm, both? Any CEL/flashing OD light?
Old Nov 28, 2007 | 02:35 PM
eskim_77's Avatar
Does it mean I have to get a new transmission?
Old Nov 28, 2007 | 02:38 PM
mowgli29's Avatar
AFAIK:
IF it is the converter, you'd just have to get the converter itself.
Old Nov 28, 2007 | 02:40 PM
eskim_77's Avatar
No CEL/Flashing OD light, and it does happen both cold and warm.
I didn't notice this until I hit the highway. During normal cruise, 2000RPM is around 60-65MPH. When I turn off OD, RPM goes up to 3000-3500.
I am having hard time to pull the car above 70MPH unless I floored the gas.
Old Nov 28, 2007 | 02:45 PM
67whitegoat's Avatar
Your description is not charicturistic of a bad torque converter. I would say your transmission is slipping.
Old Nov 28, 2007 | 02:51 PM
pmohr's Avatar
No more Maximas...
So second gear, or third?
Old Nov 28, 2007 | 02:56 PM
eskim_77's Avatar
Can this be caused by electrical/wire problem? I had hard time to remove a starter, and I could have damaged some connections or wires.
Old Nov 28, 2007 | 02:57 PM
Of course check you trans fluid, be sure it's not low.
eskim_77's Avatar
4th gear.
Old Nov 28, 2007 | 03:18 PM
mowgli29's Avatar
4th gear.
It does sound more like 4th gear than a converter. If it was a converter it would be very noticeable at low speeds, and affect every gear.
Old Nov 28, 2007 | 03:21 PM
pmohr's Avatar
No more Maximas...
It should be present in all gears, though sometimes stuff like this is only noticeable in certain conditions, however odd that may be.
Not likely, but it's a possibility. Go over that area again, see if anything is damaged.
Definitely a good idea too.
Old Nov 29, 2007 | 01:02 PM
khantalha+'s Avatar
sounds like ur trans slipping brotha.... do i see a 5 speed swap in future? jk...
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
